Old 11-03-2010, 12:48 AM   #1
sleepertruck72
sleepertruck72's Avatar
Question My truck left me...
Well my truck left me stranded at work. Luckily I can keep it parked there until I fix it. She is suffering from a no spark, no start. I used a spare plug and put it on #1 wire to the frame to see if would spark, but No spark. It is getting plenty of fuel, and has battery voltage at the wire straight from the fuse panel. It has battery voltage also on the yellow wire from the coil, but that is normal isn't it ? That's the tach side. At work we had a spare coil from another HEI, so I swapped it in, but still no spark. Still plenty of fuel. I had to leave it for the day but I was wanting to test the module. Is there a spec for ohm'ing out the module? I will try to get a better look at it all tomorrow, I put on an MSD cap and rotor about a month ago, and have been problem free until now. I removed the cap and it looked fine, so did the rotor. The weird thing is It started up fine in the morning, then at lunch I went to start and this happened, the good thing was, I still had a good lunch
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 11-03-2010, 12:56 AM   #2
Lebowski
Lebowski's Avatar
Re: My truck left me...
I had the same thing happen, I replaced the module with a cheap one and it lasted about three months. Replace with a good quality part and make sure the bottom of it is greased up good with the goo they provide with a new one.
Lebowski is offline   Reply With Quote
Old 11-03-2010, 01:11 AM   #3
sleepertruck72
Thanks for the input, Hopefully I get a chance to get er back on the road tomorrow. The thing is, it will probably easier to find a distributor, and replace as a unit rather than replace a module. I have learned to stay away from the AC Delco parts. Nothing but trouble.
72 C20 Longbed
05 1500 Z71
Old 11-03-2010, 12:11 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
Most auto parts stores should carry a replacement module. Also Auto Zone and O'Riellys test the modules for free.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 11-03-2010, 05:24 PM   #5
sleepertruck72
Well I had the ignition module tested, and two AutoZone's tested it and said it was good, not being satisfied I went to Kragen/O'Reilly's and they tested it and said it was no good. So I got a replacement that is assembled in Hong Kong, but it fired up right away.It carries a lifetime warranty which makes me believe it will last 6 months or less. They didnt have any others in stock...but good thing I got the truck home.
72 C20 Longbed
05 1500 Z71
Old 11-03-2010, 06:37 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
did you say the yellow wire was hooked to the tach terminal on the HEI?
Old 11-03-2010, 07:15 PM   #7
steppside69
steppside69's Avatar
Glad to hear you got it running! I think it is funny the ''Lifetime Warranty'' gimick, Usually the 2 year warranty part is more expensive. Has anyone noticed this? Eric
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 11-04-2010, 12:20 AM   #8
sleepertruck72
The yellow wire from the coil was what I was referring to. With the hei wire hooked up, I removed the coil cover, to inspect the wires and both(red B+ side, and yellow C- side) had battery voltage. I was thinking that was normal ? I swapped the coil with a known good coil and no change, still no spark and same voltages. If I am wrong, please let me know
Yeah I agree, and I'm just glad I found the part. Around here they tend to not stock stuff ! Come to think about it, I should of bought 2. I think I will order an extra from Summit to be on the safe side. This one was stamped Assembled in Hong Kong. Im crossing my fingers
Thanks for the input guys !!!
72 C20 Longbed
05 1500 Z71
