Old 11-03-2010, 09:26 AM   #1
dznucks
dznucks's Avatar
Help finding Input Shaft Bearing for 3 speed
I have a three speed transmission that I believe is a Muncie. I just replaced my clutch assembly, pilot bushing, and input shaft bearing. I took the old input shaft bearing to a reputable, local tranny shop to ensure that I got the right bearing. They gave me a N307LOE bearing. I noticed the bearing was just a bit shorter (~.040") than the original and the guy at the shop told me that wouldn't make any difference.
Now the tranny has been popping out of third gear and i can feel some play in the transmission while driving. I am assuming that this .040" width difference is causing the problem.
The original bearing has the following dimensions.....ID 1.378" (35mm), OD 3.152" (80mm), and a width of .709" (18mm). The new bearing has the same ID and OD, but the width is .669".
Can someone tell me how to find the correct bearing?
dznucks is offline   Reply With Quote
Old 11-03-2010, 10:16 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Help finding Input Shaft Bearing for 3 speed
Look for a bearing shop or store in your area.
I had a similar problem with a bearing years ago and a mechanic told me to go to a local bearing shop. They got the number and measurements off the original and matched it perfectly.
Hopefully you kept the original bearing so a bearing shop can get the number off of it and get the right one for you.
68gmsee is offline   Reply With Quote
Old 11-03-2010, 10:32 AM   #3
dznucks
dznucks's Avatar
I actaully have a spare tranny thats identical, so i have two of these bearing made by different manufacturers and with different part numbers.
I'll give that a try.
thanks
Old 11-03-2010, 01:51 PM   #4
dznucks
dznucks's Avatar
The stampings on the transmission are M5P05A. Based on what i have read online about decoding this, I have a Muncie M20 out of a '65 vehicle.
Can someone confirm this?
Old 11-03-2010, 07:08 PM   #5
dznucks
dznucks's Avatar
I think i have made out the bearing numbers.
Can someone cross reference a New Departure Bearing? NDH 43307AD
Old 11-03-2010, 07:31 PM   #6
LandonL
LandonL's Avatar
I have one for a Muncie SM318 that I didn't use, two actually. Is yours a SM318, 3spd? I have a picture of mine.
You may also find it at rockauto, I just check and they have one. Not sure of dimensions.
You sure the shifting rod to the gear selector isn't loose?
---| 1967 GMC Stepside |--
250 L6 .030 over
---| 1985 Porsche 944/1 |---
Build Thread: '67 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=378640
LandonL is offline   Reply With Quote
Old 11-03-2010, 07:45 PM   #7
dznucks
dznucks's Avatar
No, my transmission doesnt look exactly like that. The main body is a little longer, but the tail shaft is smooth like yours, no bosses or tranny mount locations.
I have shifted the transmission by hand, from underneath, and it shifts smooth and solid. I'm pretty sure the problem is the bearing.
Old 11-03-2010, 07:46 PM   #8
LandonL
LandonL's Avatar
Ah well, best of luck to you!
250 L6 .030 over
Old 11-03-2010, 08:00 PM   #9
Zeke
Active Member
I did a search and there is a Timken company in Smyrna, 3300 Highlands Pkwy SE Ste 295 · Smyrna.
I have replace lots of bearings in parts that only came as assemblies at parts stores. Can't beat $5 for a bearing vs $40 for the whole part.
As said before take your old bearing if you have it or the part number and they can match it up. Also was there a shim in the front housing? Many times a shim is used to get the end play right.
Also check the detent cam in the side cover, might be worn or spring weak.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 11-04-2010, 07:24 AM   #10
dznucks
dznucks's Avatar
I am going to try Applied, down south of the airport. I have heard they can match any bearing.
There was not a shim in either of the transmissions. i thought about finding a metric washer or something to shim the play between the bearing and the small c-clip. But that wont help the play between the inner side of the bearing and the input shaft. The larger C-clip keeps the bearing from going into the transmission. Since this new bearing is .040" shorter in that dimension, theres .040" play inside of the tranny.
Old 11-04-2010, 08:05 AM   #11
dznucks
dznucks's Avatar
I did find this on a buick forum. I may give 5speeds.com a call.
http://70.86.163.37/showthread.php?p=1570558
Old 11-04-2010, 08:48 AM   #12
raycow
If you have the HD Muncie 3 speed, the GM designation for that is SM330. It has a 7 bolt side cover and is often confused with the much more common Saginaw (SM326) which it superficially resembles. As you have found out for yourself, its parts do NOT interchange with the Saginaw.
The .040" shim between the thinner bearing and the gear should be a workable fix, but I am surprised that your bearing house can't interchange the NDH number.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-04-2010, 09:27 AM   #13
dznucks
dznucks's Avatar
I actaully have two of the Muncie's and a Saginaw in the shop.
The two muncies were built several years apart and use the exact same bearing. That's why I find it hard to believe its not easier to find the right bearing for this tranny.
Old 11-04-2010, 06:36 PM   #14
dwcsr
Hollister Road Co.
dwcsr's Avatar
Try rockauto.com
https://www.rockauto.com/dbphp/x,car...6_Bearing.html
dwcsr is offline   Reply With Quote
Old 11-04-2010, 08:36 PM   #15
dznucks
dznucks's Avatar
Thanks dwcsr. those are the only bearings i am finding and they aren't the right ones.
I spoke to Applied Technologies (Atl Bearing shop) today and they said the bearing i am looking for is obsolete. The only thing that I can do is shim the N307LOE bearing that I have in it now.
Surely I am not the first person to run into this issue.
Old 11-04-2010, 08:44 PM   #16
LandonL
LandonL's Avatar
Did you get rid of the old one?
250 L6 .030 over
Old 11-04-2010, 09:08 PM   #17
dznucks
dznucks's Avatar
no, i have both the old ones. i am starting to think that replacing the bearing was a waste of time and money. I just thought i would replace it while i had it out.....the tranny came from a board member and i wasnt positive of the bearing condition.
I may put the best bearing back in or use some shims (arbor shims) to shim the new bearing back out.
Old 11-04-2010, 09:28 PM   #18
LandonL
LandonL's Avatar
I would vote put the best one back in, and if you still have the problem, you'll know it's not necessarily the shaft bearing and you can debug from there.
250 L6 .030 over
Old 11-04-2010, 11:53 PM   #19
vectorit
What?
vectorit's Avatar
Hit up these guys.
http://www.anaheimgear.com/
They had parts for my stuff.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-05-2010, 09:19 AM   #20
dznucks
dznucks's Avatar
Hit up these guys.
I sent them an email. Pat, at Anaheim, knows about this bearing and he has a source for replacement bearing. He didnt share the source or part number. He wants $40 each, but the shipping to the opposite coast is going to make it cheaper to go with the new N307LOE I already have and use arbor shims to shim the extra gap.
I have ordered some .020" arbor shims from grainger. I am going to try to use two of these arbor shims to take up most of the .042" gap.
http://www.grainger.com/Grainger/Arbor-Shim-5GB24
