11-03-2010, 11:46 AM | #1 |
stock radio repairs???
Anyone ever attempt to fix a g m stock radio? Mine looks great but did not work when I bought truck. Thought someone might aim me in a direction to look at. Just looking to listen to some news and such. Don't want to cover up too many rattles, they are MUSIC to me. Gary
11-03-2010, 12:47 PM | #2 |
Re: stock radio repairs???
makin sure the case has a good ground,the antenna connection is bright and shiny, trying another known good speaker and spraying the tuner control real good with tuner lube cleaner(radio shack)// is a first step to determine if it works
11-03-2010, 03:29 PM | #3 |
I might be able to help with this one. I had my factory AM/FM Stereo Delco unit out of the '76 Stingray I used to own by this guy:
http://www.wonderbarman.com/ I think he charged me $150.00 (which is CHEAP if you've ever priced some of these old STEREO Delco's!) and I didn't want to cut up any of the dash on the old Vette... Molded vinyl and what not. Anyway, the internal amp was blown and he did a complete refurb. Took about 2.5 weeks from the time it left until I got it back and it worked and looked GREAT. Highly recommend.
11-03-2010, 03:53 PM | #4 |
Will try all of that thanks, If not has anyine ever had one apart to attempt to fix? A fuse, diode, short???? just wondering. Gary
11-15-2010, 09:55 AM | #5 |
72 GMC
bump
11-15-2010, 02:48 PM | #6 |
If you decide to take the cover off look for bad solder through connections. These connections are soldered on both sides of the circuit board and are often cracked. A hot iron and some solder will fix them up. Back in the day I fixed many Delco’s this way.
