Old 11-03-2010, 12:53 PM   #1
Ms Bright
Talking My First: 68 Frame-off rebuild
I have a 68 Chevy short bed that WAS my daily driver. I knew eventually I would restore her; I love this truck so much I had her tatooed on my arm! After blowing a freeze plug and locking up the motor, I decided to do a full frame-off restoration.
I have two BIG dogs that love to ride around in the back of my truck but, one's getting too old to jump. So, I decided to step notch the frame and bag it so my truck will drop to the ground. Then the dogs can load up without backing down the ditch. Plus, it'll look WAY cool...
I purchased the front dropped crossmember assembly, sway bar and rear 4link cantilever with step notch and watts link from Chris Alston's Chassisworks. The instructions are so easy even a chick can do it herself! (I know this for a fact... )
So far, I've had the frame sand blasted, cut the frame out for and installed the notches and all bolt and weld-in components. (I'm having the welding done by a pro but doing everything else myself). I've painted the frame, and had my rear end rebuilt with positraction. I painted the rear end and axle last night gloss black and it looks good, if I do say so myself! I have purchased the brake kit to swap drum brakes for disk all around and switched to a 5-5 wheel bolt pattern in the process. My spindles get here the 9th so I'm on my way!
One question... where do you put the spare?!?
Ms Bright is offline   Reply With Quote
Old 11-03-2010, 01:54 PM   #2
ControlFreak
ControlFreak's Avatar
Re: My First: 68 Frame-off rebuild
I think that it's great that Ladies are involved in our passion for old trucks. Look's great, I wish you the best. Keep it coming.
Alan
ControlFreak is offline   Reply With Quote
Old 11-03-2010, 02:37 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Welcome! And good luck with what looks to be a SICK build! Keep at it, cant wait for more pics.
--Josh
Old 11-03-2010, 02:57 PM   #4
Chainhoist Catapult
That is going to be sweet, where did you have it media blasted at? And what coating are you using for the frame and axels? My wife doesnt know it yet but she is going to be my assitant mechanic.
Chainhoist Catapult is offline   Reply With Quote
Old 11-03-2010, 04:08 PM   #5
69CST-V
69CST-V's Avatar
Great start. I will be watching.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 11-03-2010, 06:15 PM   #6
Ms Bright
I'm having my sandblasting done at Rob Carroll's Sandblasting & Painting in Arkansas City, KS.
I bought Industrial primer and Enamel at Orschelyn's to paint the frame, axle, rear end... the little stuff BUT my paint is going to be done in Nixa, MO at Curry's Hot Rods Inc.
Thought I'd put some pics of my 20" Foose rims up while I'm here.
Old 11-04-2010, 11:19 PM   #7
butternut1972
butternut1972's Avatar
Nice project! subscribed
butternut1972 is offline   Reply With Quote
Old 11-04-2010, 11:31 PM   #8
KillerMinPin
KillerMinPin's Avatar
Your doing an AWESOME job!!! Can't wait to see more pix as you get more and more done.
KillerMinPin is offline   Reply With Quote
Old 11-09-2010, 02:31 PM   #9
Ms Bright
I had to go out of town for the weekend for a wedding so I didn't get anything done Saturday or Sunday...BUT; heres what I did Monday.
I installed the rear brakes, cantilever, bags & shocks.
I get my front spindles today (WOOHOO!)
Old 11-09-2010, 05:17 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Great progress, and project!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-09-2010, 05:37 PM   #11
m6z
m6z's Avatar
Nice build. Good to see another kansas build.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 11-09-2010, 08:57 PM   #12
jmking9
jmking9's Avatar
^x2 Nice looking build. BTW, What part of KS you in?
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 11-09-2010, 09:14 PM   #13
bigguy69
dazed and confused
bigguy69's Avatar
awesome!!!!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 11-09-2010, 09:42 PM   #14
lolife99
67-72 parts collector,…
lolife99's Avatar
Welcome to the board!
Looks like a really nice project.
You do GREAT work!
Keith
Convert to disc brakes.
Old 11-18-2010, 02:51 PM   #15
Ms Bright
I have ran into a problem. The upper and lower control arm mounting studs are SUPPOSED to fit into the tapered holes on the spindle with enough stud left to torque a castle nut on and insert a cotter pin. As it is now, I can get the castle nut on but it's like the tapers don't match up. I have a couple of threads sticking out and the dang things (top AND bottom) just don't go on any further. I purchased the control arms and spindles together in a kit so, unless I was shipped the wrong parts, I'm just stumped. I called the place I bought them from and the "tech" said to buy a tapered reamer. These things cost, like, $90 minimum! why in the world would you have to go buy a reamer to get two parts to work together when they were purchased as a set!?! I have tried two spindles I have that weren't purchased from this supplier and they won't slide on far enough, either. I can't feel any burrs, there is no rust on or in either taper and I even tried a slight coat of grease. Does anyone know the taper on drop spindles for a 73-87 and where can I beg/borrow/buy the tapered reamer as this may be what I resort to. I only need about 3/8" and it'd be good. Anyone have any advice? HELP!!!
Old 11-18-2010, 03:13 PM   #16
lolife99
lolife99's Avatar
DO NOT ream the spindles.
You have the wrong balljoints or the wrong spindles.
There are three different upper ball joints.
63-70
71-72
73-87
There are two different lower ball joints
63-70
71-87
You got the wrong parts.
You just have to figure out which one is incorrect.
Keith
Old 11-18-2010, 03:15 PM   #17
lolife99
lolife99's Avatar
It sounds like you have 73-87 balljoints in your control arms and 63-70 "disc brake conversion" spindles
If the "Tech" at the Suspension Company told you to buy a taper reamer,... he should be fired or moved to a different department.
Keith
Old 11-18-2010, 03:17 PM   #18
72BlckButy
Tot Roddin'
72BlckButy's Avatar
It sounds like you have 73-87 balljoints in your control arms and 63-70 "disc brake conversion" spindles.
Agreed.... that's opportunity for a lawsuit if something went awry.
-Nate
Old 11-18-2010, 03:18 PM   #19
Ms Bright
Thanks, Keith. I'm removing the control arms and taking them and the spindles to a mechanic in town. If he can't help me out then I'm off to the parts store to get what I need. The packing list I received from my supplier says 63-70 upper and lower control arms and 73-87 spindles. Are you telling me that these parts are not supposed to fit each other?
Old 11-18-2010, 03:21 PM   #20
lolife99
lolife99's Avatar
Incorrect.
They are suppose to fit each other. Ha.
The spindles and the control arms have to match.
The easiest solution would be to buy 73-87 balljoints to match your spindles.
I would confirm that at the parts store.
Take a spindle in and see exactly what they sent you.
Keith
Old 11-18-2010, 03:23 PM   #21
lolife99
lolife99's Avatar
Are you running tubular control arms?
I would hate to swap out brand new parts when the supplier made the mistake.
Keith
Old 11-19-2010, 11:43 AM   #22
Ms Bright
O'Reilleys helped me out ALOT. I bought new ball joints last night and am putting them in today... here's hoping for no problems! Atleast now I'll know how to use a balljoint press! ! I'll either be posting proud pics or venting like a crazy woman in the very near future!
Old 11-19-2010, 11:45 AM   #23
Ms Bright
I didn't return my control arms or wait for them to send me the right ball joints cause they gave me a three week lead-time and I'm not waiting.
Old 11-19-2010, 04:01 PM   #24
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Glad to hear that worked out for you.
-Nate
Old 11-19-2010, 06:42 PM   #25
STOCKISH
STOCKISH's Avatar
Glad you figured it out. Cant believe the tech told you to ream out the spindles. What an idiot!
--Josh
