floor shifter conversion?
i have a 67 GMC with the 3 speed column shifter. I want to switch this to a floor mount 3 speed. does anyone know where the hole for the shifter would actually need to go???? i also plan on putting bucket seats in. any pictures or diagrams would be great or suggestion on which shifter to use.
Thanks. |
Re: floor shifter conversion?
http://www.classictrucks.com/tech/05...ion/index.html this should help you out.
horsepower sells cars torque wins races. "caroll shelby" |
easy way is install on tranny while you're under truck look up then make hole and take the two bolts and bolt shift handle on linkage
![]() Join Date: Oct 2007
This is how I did mine. The hole does not need to be to big either. Start small (like 2" x 3") and enlarge it only as much as you need to.
![]() Join Date: Jul 2010
Where do you suggest to buy the kit from?
The Hurst shifter and kit fits the 7 bolt side cover full synchro tranny's. You probably have a 4 bolt side cover non 1st gear tranny. I used a Mr. Gasket #7667A shifter in my 67 gmc. The hurst shifter brackets and linkages need a bunch of mods to fit. The 7667A is a universal one that comes with multiple brackets and easy to install. Got mine on ebay for 80 bucks shipped to my door.
Too many projects
I tend to eyeball it and put a sheetmetal screw in the top where I think it should be, then get back under it and adjust my eyeball measurements based off where the screw sticks out. If it's off too much, you only have a tiny hole in the wrong spot.
Start small and adjust as needed. Oh, I had a Mr. Gasket shifter and it kept binding in 1st and 2nd at once. I'ld jump out, pull the linkage by hand under the truck and then fire it back up and be on my way. I have a hurst shifter now and life is much better; I can slam gears all I want and it only goes in one at a time!
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" Last edited by lowrollin70gmc; 11-03-2010 at 07:46 PM. |
Hurst shifters don't hang up I agree but I've had 4 Mr. Gasket ones and have never had one hangup yet. You just gotta know how to set them up.
