Old 11-03-2010, 07:21 PM   #1
UNT8MDGT
UNT8MDGT's Avatar
Converting to dually?
Hey Guys, I Just picked up an 81 SWB Chev, its pretty rough but hopefully i can get it going for this summer coming.
I want to convert it to dually and run the 22.5 truck rims on it.
What exactly will i need to do the conversion?
I know i need the rear fender flares and will I have to use a 1 ton dually rear? or is there adapters to run my stock rear?
any help/advice would be great!
Thanks in advance guys
UNT8MDGT is offline   Reply With Quote
Old 11-03-2010, 09:30 PM   #2
BigBlocksRule
Re: Converting to dually?
Spend the money once, get a cab & chassis rearend. That's what the guys doing this conversion are using to get 'em to fit. If you use the regular dually rear, you'll have to rework the fiberglass fenders, much more expensive. I just sold a C&C with 4.56 cogs last weekend for $400.
BigBlocksRule is offline   Reply With Quote
Old 11-03-2010, 09:51 PM   #3
UNT8MDGT
UNT8MDGT's Avatar
Sorry for the noob question but when you say "get a cab & chassis rearend"
does that mean from a crew cab dually?
also will i have to run the 8 lug hub/spindle assembly up front?
i cant find any info on the swap on the NET.
Thanks again
Old 11-03-2010, 10:09 PM   #4
cochino12
It followed me home?
cochino12's Avatar
cab and chassis rear is a bit narrower than a rear end from a typical dually. Its really not necessary unless you are planning on getting it low enough to lay frame.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 11-03-2010, 10:23 PM   #5
UNT8MDGT
UNT8MDGT's Avatar
What do they usually come from?\
I was planning to lower it 5/6, but will i be able to use the typical drop spindles up front and shackle kit for the rear? i eventually want to run the 22.5" rig wheels on it. i know i will have to run adapters for those wheels but what should i do about the front only being 5 lug?
sorry again for all the noob questions
Old 11-04-2010, 01:13 AM   #6
pig rig
pig rig's Avatar
It helps to know if your truck is 3/4 or 1/2 t and if its 2wd or 4wd
lets say its 1/2 2wd just to make it easy. you need 1t upper balljoints lower 1t a arms and 1t spindels and rotor and break and the flexable break line
I did a right up on the front ends and what interchanges on dually scene and I've posted it here also but I'm not finding it
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 11-04-2010, 06:23 AM   #7
BigBlocksRule
The C&C is actually about 6" narrower than the regular dually.
Old 11-04-2010, 12:37 PM   #8
UNT8MDGT
UNT8MDGT's Avatar
Ok perfect i did a little more searching and found out what i could get the rear from. I also just found out about a crew cab dually thats being parted out so ill probably end up just grabbing everything from it, if i cant get the parts from the scrapper.
and sorry the truck is 2wd 1/2 ton, and ill take a look over at dually scene to see what i can find
Thanks guys
