11-04-2010, 06:00 PM | #1 |
1960 burban frame swap
Just found a 1960 suburban/carryall and want to swap the frame from it due to it being damaged by the front frame horns. I was wondering if a 60-66 short box frame will work?
11-04-2010, 06:08 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: 1960 burban frame swap
I dont think so, I belive it will be a LWB frame that will work. do you know the wheel base on your sub? I think 115" is SWB and 127 is LWB. I would also look at a 63-72 frame, 71-72 will have the disc brakes already and also you need to make sure you are looking for a coil spring rear.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-04-2010, 06:16 PM | #3 |
The factory specs on the suburban is 115" wb, same as the swb. My plan was to get a 63-66 frame, swap out the cross member with a 73 c10 cross member to get the disc brakes, then install a 70 coil spring rear end in it.
11-04-2010, 06:17 PM | #4 |
all suburbans were 115" wb . 63-66 are the easiest to put under. you have to relocate the body mounting location on the floors. on the 67-72 frames there are some differences mainly in the formation of the frt frame horns and some crossmembers are different
bbc. i did send you a pm ron |
11-05-2010, 12:39 AM | #5 |
60-66 Nut
Yes a short wheelbase truck frame would work. But as padresag said you will have to change/add the body mounts for the Burb body. A little FYI for you, any '71-/87 front suspension will work for your disc brakes up front. The 5 lug rear ends started in '71. The '71 & '72 trailing arm rear ends will be a direct bolt in into the '63-'70 frames with trailing arm suspensions. The '73-'87 rear ends will work as well, but with some cutting and welding to accomodate the trailing arm suspension. Also the '71-'87 rear ends are 1.5" wider than the '63-'early '70 rear ends.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 11-05-2010 at 12:39 AM. |
11-05-2010, 04:43 AM | #6 | |
You will have to cobble the fuel tank mounts on the pickup frame, but that shouldn't be too bad. Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
11-05-2010, 12:10 PM | #7 |
I think there is some step down in the last foot or so of the frame rails on the suburbans that is not common with the pickup. Something to look for....
11-05-2010, 01:23 PM | #8 | |
Ray
11-06-2010, 12:20 AM | #10 |
60-66 Nut
Yes that's right, I forgot about that as well as the rear frame horns to accomodate the rear bumper.
