Old 11-04-2010, 07:13 PM   #1
repeeler
repeeler's Avatar
Input needed on swapping a 350 for a 700r4
I have decided I am going to put a 383 small block EFI motor in my 71 truck from Smeding Performance here in Texas. I am thinking I should go ahead and install a 700r4 in place of the Turbo 350. I know a few of you here have done this. What will I need to do to swap to the 700r4?
Ray
1971 Cheyenne LWB
1965 C-10 Short Fleetside 350/350
2010 Harley Davidson FLHTK
repeeler is offline   Reply With Quote
Old 11-04-2010, 08:17 PM   #2
cparman
sharp as a marble
Re: Input needed on swapping a 350 for a 700r4
there is a bunch of info on this great site about this swap. The 700 is longer, and you will need to move the crossmember, install a TV cable, I recommend a LOKAR cable and the bracket to the carb. IF you are using a big cammed motor you will need some help with a stall converter. I have bought two converters from Precision Converters. Yes, they are pricey, but my 67 Chevelle, zz502 idled at less than a 1000, and had a 9 1/2 2800 stall. You could drive it 25 mph with no slip, and did not have any indication of a small converter. Made that BB feel like a SB.
The other converter was in a Buick Grand National 11.50 @ 120 mph. I would drive this car to Gainesville raceway (100 miles) and play all night, and then drive it home. windows up and the A/C on. GREAT PRODUCT!!
cparman is offline   Reply With Quote
