Old 11-05-2010, 12:43 AM   #1
alabamachevy15
alabamachevy15's Avatar
383 Stroker????
What do yall think about this engine? Never heard of this place but it seems to be a good engine! I was planning on a 434 but I wanna still drive it on the street! Plus I can drive to pick it up!
http://www.wheelerpowerproducts.com/...ailedSpecs.pdf
03 silverado RCSB
Headers,Magnaflows,K&N,EFI Live,Truetrac,4:10s
84 silverado RCSB
Work in progress
alabamachevy15 is offline   Reply With Quote
Old 11-05-2010, 07:24 AM   #2
xrcr
Re: 383 Stroker????
Never heard of them either. Price is right. I'd try to see if they willl give you information on who is running these and check that out. Do they warranty anything? GM sells crate motors for pro crate late models for around the same price but the compression might be tough to street.
xrcr is offline   Reply With Quote
Old 11-05-2010, 08:19 AM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Re: 383 Stroker????
Their price is about right. The aluminum heads should make up for the 10 to 1 compression ratio. Still, do not be surprised if you have to run a higher octane gas for the spark knock issues. A little lower compression ratio would make it more streetable, but you would loose a little HP in the long run. I have never heard of these guys, before.
I went to a local machine shop and built my 383 for the truck that is in my avatar. I have about the same invested in mine.
Frank
piecesparts is offline   Reply With Quote
Old 11-05-2010, 08:31 AM   #4
alabamachevy15
Re: 383 Stroker????
I thought that price was good cause the speed shop here where I live wants $3,800 just for shortblock+cam. I dont care about the higher octane gas as I always run 93 even in my new chevy. I just want something with lots of torque and I can take to the track and make decent times.
03 silverado RCSB
84 silverado RCSB
Work in progress
Old 11-05-2010, 09:38 AM   #5
baclay9
Re: 383 Stroker????
Just FYI my motor was 10.2:1 compression and it pre-detonated with 91 octane no matter the temp. You may have to run octane booster as well. I am currently changing pistons to bring compression down to 9.5:1. Buying octane booster for every tank in expensive.
baclay9 is offline   Reply With Quote
Old 11-05-2010, 10:48 AM   #6
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: 383 Stroker????
You can run a lot more compression on pump gas than most people think if you use the correct cam timing, quench and chamber design. I run 10.5:1 compression with iron vortec heads on my 383 and run 91 octane with no issues. Compression is your friend if you like snappy torquey engines, I always run as much as I can get away with.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 11-05-2010, 10:04 PM   #7
justinburnett
justinburnett's Avatar
Re: 383 Stroker????
Didn't some of the corvettes run an 11:1 stock back in the day? Might just be pulling numbers out of my head, but it seems like it was the late sixties or first couple years of 70s.
justinburnett is offline   Reply With Quote
Old 11-05-2010, 10:10 PM   #8
justinburnett
Re: 383 Stroker????
Okay, this must have been where I got my info. It's off wikipedia (don't know why it stuck in my head). So would you have to use special fuel for this engine back then?
* LT-1
LT-1 from a 1970 Chevrolet Camaro Z28
Years: 1970–1972
The LT-1 was the ultimate 350 cu in (5.7 L) V8, becoming available in 1970. It used solid lifters, 11:1 compression, a high-performance camshaft, and a 780 CFM Holley four-barrel carburetor on a special aluminum intake with ramhorn exhaust manifolds and a low-restriction exhaust to produce a factory rated 370 hp (276 kW) (the NHRA rated it at 425 hp for classification purposes) and 380 lb·ft (515 N·m). Redline was 6500 rpm but power fell off significantly past 6200 rpm. The LT-1 was available on the Corvette and Camaro Z28. Power was down in 1971 to 330 hp (246 kW) and 360 lb·ft (488 N·m) with 9:1 compression, and again in 1972 (the last year of the LT-1, now rated using net, rather than gross, measurement) to 255 hp (190 kW) and 280 lb·ft (380 N·m).
Old 11-06-2010, 12:29 AM   #9
foamypirate
foamypirate's Avatar
Re: 383 Stroker????
Fuel from the 60's and early 70's had lead, which acted as an octane booster. That's why they were able to get away with higher compression back then. Nowadays, it's due to chamber design, head material, and quench.
foamypirate is offline   Reply With Quote
Old 11-06-2010, 12:50 AM   #10
alabamachevy15
Re: 383 Stroker????
Yea this new gas is crap for high performance engines. I know of only one station around here that sells gas without ethanol and its $3.99. But I do wanna go with the most compression I can im just gonna call this place and tell them what im looking for and give them a budget to build on.
03 silverado RCSB
84 silverado RCSB
Work in progress
Old 11-06-2010, 08:55 AM   #11
80SPORT
80SPORT's Avatar
Re: 383 Stroker????
Your best value is a brand new GM crate engine....24 month/50000 mile warrantee good at any GM dealer.Available from a GM dealer or numerous online vendors.There are 2 versions -the standard vortec HT model with 340 HP and the zz383 with aluminum heads and 425 HP.
See details at gmperformanceparts.com
GMs horsepower ratings are done to SAE standards and are very conservative...especially compared to some aftermarket claims.
These engines are all brand with new 4 bolt main block,forged crank with 1 piece seal,roller camshaft etc.
They also have a slightly longer stroke than aftermarket 383 motors as GM engineering requires them to start with a standard bore block.
Most aftermarket 383 motors have a 030 overbore with a crank speced for the original 400cid.
We have used both of these engines;the HT is perfect for a dually or a crewcab;the zz works best in a short box with a lower gear ratio.
80SPORT is offline   Reply With Quote
Old 11-06-2010, 10:22 AM   #12
russgt
russgt's Avatar
Re: 383 Stroker????
gm's prices are usually high though, could probably have the exact motor that you want built cheaper. Keep in mind that with a crate motor, modify anything and your warranty is gone.
ZZ4 350/350 hp $5299 plus shipping
http://www.summitracing.com/parts/NAL-19201330/
HT383 340hp $4800
http://www.summitracing.com/parts/NAL-12499101/
his motor
383/ 450 hp $4700 pick up
The zz does come ready to run, not real clear on the 383 with what it comes with
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 11-06-2010, 11:28 AM   #13
Dru
Re: 383 Stroker????
You could always learn to build it yourself, assembling a 383 isnt that hard, and you would learn something along the way. Its just a 400 crank in a 350 block.
I prefer the 377's myself for a small block, which is a 350 crank in a 400 block, they'll spin up a lot quicker. But I dont have much use for small blocks anyhow.
Dru is offline   Reply With Quote
Old 11-07-2010, 12:41 AM   #14
alabamachevy15
Re: 383 Stroker????
I have looked into the gmpp engines but they are expensive and and for those prices I can have alot more HP! But im not knocking gmpp they do build great engines and they are reliable I know several people who have gmpp engines in their dirt track latemodels and run up front every night. But I will probally end up buying from Wheeler they are close so I wont have to pay shipping and I can actually go and talk with the people who built the engine.
03 silverado RCSB
84 silverado RCSB
Work in progress
Old 11-07-2010, 07:22 AM   #15
BigBlocksRule
Re: 383 Stroker????
No brand name on the heads?
Probably ProComp.
Same quality as you buy at Harbor Freight, which makes sense since they come from the same place.
Roll your own, there's nothing like it.
BigBlocksRule is offline   Reply With Quote
Old 11-07-2010, 11:08 AM   #16
68 TT
Still plays with trucks
68 TT's Avatar
Re: 383 Stroker????
They also had much higher octane fuel available in the 60's too. It is not all just due to the lead content. Some engines from Chevy in the late 60's like the L88 and ZL1 even ran 12.5 to 1 compression. The L-88 cars came with a sticker saying they needed 103 octane fuel. Not very many of those but there much more out there that ran 11 to 1 like all the 375 hp 396's and the Z/28's 302. Almost everything else ran 10.25 or so until the unleaded gas change over occurred in 71 or 72.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-07-2010, 11:28 AM   #17
BigBlocksRule
Re: 383 Stroker????
Lead didn't boost octane, it acted as a "cushion" or lubricant for valves and seats. That's why we need hardened seats with unleaded fuels.
Octane is a fuel's resistance to detonation. Modern combustion chamber shapes are part of today's puzzle, the computer and injectors are the other things that let us run a bit more compression than through the 70's and 80's.
Old 11-07-2010, 11:38 AM   #18
piecesparts
Re: 383 Stroker????
I agree on part of lead discussion, but the computer only works to reduce timing when detonation is happening. It will retard the ignition until you are sucking the hind leg of the rat that is eating your dust up fast. That is why the sales of tuners is going through the roof on late model cars. To get more compression and run a computer, you have to build to the standard of head and cam profile design or keep the compression ratio down to a good level.
If you run a carb, then you run the engine to your own desires, not what a computer will do for you.
Frank
Old 11-07-2010, 11:42 AM   #19
68 TT
68 TT's Avatar
Re: 383 Stroker????
Probably ProComp.
All the house brand parts on there and like stated above the lack of a brand name for the heads, cam & intake bother me. For the money they are asking you can build your own with known quality name brand parts.
Building your own is the only way to go.
A set of AFR 190's and a Comp hydraulic roller setup will run you less than half their asking price and you can get a good quality Scat 383 forged rotating assembly with H-beam rods for under a $1850. That leaves you plenty of money to come up with a rebuildable 4-bolt block and have it machined.
Getting all the new tin, fasteners and intake will bring the cost a little above their asking price but you will end up with a better quality engine that will last longer in the end.
Old 11-07-2010, 12:03 PM   #20
piecesparts
Re: 383 Stroker????
The whole thing abut a stroker engine is that the block is good enough to stand up to the machine work that oyu do to it. You have to remove a lot of metal inside for clearance and then you want to have quality parts to stand up to the hell that you have convinced yourself to give it. You don't need a 4 bolt main setup, but it helps. The older blocks, known as "heavy blocks" is the best. They have more metal available to use. The HP is in the heads and cam profile for the stroker engine.
Frank
Old 11-08-2010, 09:22 AM   #21
Long79
Long79's Avatar
Re: 383 Stroker????
You can't buy gas with out ethanol, gas company's put it in right at the refinery, it is used to get the correct octane, this guy is just trying to scam people
79, C-10, long bed, Std cab, 2wd, 305, 4 barrel Q-jet Turbo 350.
How does it work? P.F.M. How do you fix it? B.F.H.
Long79 is offline   Reply With Quote
Old 11-08-2010, 11:22 PM   #22
alabamachevy15
Re: 383 Stroker????
http://pure-gas.org/index.jsp?stateprov=AL
Its called midtown service station. Brewton,AL I think theres a few more too! LOL
http://pure-gas.org/index.jsp?stateprov=NC
Heres some in North Carolina
03 silverado RCSB
84 silverado RCSB
Work in progress
Old 11-09-2010, 10:22 AM   #23
Long79
Long79's Avatar
Re: 383 Stroker????
just called shell to find out bout this they told me ALL shell gas has ethanol in it, may only be a couple of % but it is in there to correct octane.
Old 11-09-2010, 01:05 PM   #24
rfmaster
rfmaster's Avatar
Re: 383 Stroker????
The US EPA first announced regulations to limit the amount of lead in gasoline in November 1973. The new regulations mandated that the lead content for all grades of gasoline be restricted to 1.7 grams per gallon by July 1, 1975. The new gasoline lead regulations were based on ‘total pool averaging’-“a method which allows refiners to average lead usage over all grades of gasoline produced, including the unleaded grade”. Unleaded gasoline was readily available when catalytic converters were installed in new cars beginning 1975 model year.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 11-09-2010, 01:55 PM   #25
68 TT
68 TT's Avatar
Re: 383 Stroker????
//RF
GM was ahead of the regulation by a year or so. Most of the muscle cars were set up to run unleaded fuel and lower octane fuel in 71. That drop in compression is the main reason the HP numbers dropped from 70 to 71. In 72 they changed the way the test was performed to measure HP so the numbers dropped again in 72 even though most of the engines were identical to the 71 version.
