Old 11-05-2010, 01:09 AM   #1
cur88alan
Speedometer Swap?
Does or has anyone done a speedometer swap to something electronic and programmable for big tires and lift i have a 1975 k10 with 8" lift 39.5x15 tires and my speedometer is way off i would like to upgrade to something that i can plug into a computer and just reprogram to work with different tires
cur88alan is offline   Reply With Quote
Old 11-05-2010, 05:19 AM   #2
raycow
Re: Speedometer Swap?
I haven't seen any aftermarket speedos that you program with a computer. The ones I looked at had either a row of dipswitches that you set according to a table or a calibration button that you use in conjunction with driving over a measured distance.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-05-2010, 05:36 AM   #3
bikes&bowties
bikes&bowties's Avatar
zi just drove with a gps for a day and dont worry to much. in MPH 32=35, 50=60, 55=65, 60=75, 75=hauling ass with poorly balanced mud terrains=vibrations
bikes&bowties is offline   Reply With Quote
Old 11-05-2010, 09:08 AM   #4
willett
Another Day, Another Dollar
willett's Avatar
you can swap out your speedo drive gear relitivlely inexpensively
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 11-05-2010, 02:29 PM   #5
cur88alan
i was thinking more like swapping in a speedometer from a newer truck like a 2010 tahoe has a programmable speedo all you have to do is plug in basically a code reader and imput your tire size and lift and it recalibrate's the speedo
Old 11-08-2010, 12:29 AM   #6
cur88alan
anything from anyone
Old 11-08-2010, 02:51 AM   #7
raycow
Does a speedo like you are describing run directly off the signal from the VSS without any intervening processing?
Ray
Old 11-08-2010, 04:34 PM   #8
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
If you buy an aftermarket electronic speedometer, it should come with a sending unit that screws into the stock cable hole. Then you drive a preset distance and push a button and you're good.
I'm setting one up in my nova right now.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 11-08-2010, 04:46 PM   #9
cur88alan
where can i buy one of these
Old 11-09-2010, 07:36 AM   #10
greguw
You can go with a electronic speedo and replace your cable with a pulse generator . The all you have to do is set your revs per mile for your tire size ...Thats what I am doing with 41's .
Autometer has a nice selection of speedometers .
greguw is offline   Reply With Quote
Old 11-11-2010, 02:08 PM   #11
cur88alan
what is the size of our stock speedometer
