11-05-2010, 09:44 AM | #1 |
Can I fit a 1.25 spacer on rear with Boss 20x10?
I am going to mount Boss 20x10's with 1.25" spacer on the back of the 67 but the rearend is the wider 70 rearend. Anyone running these sizes? The Boss wheels have a 6.25 Back space, so calculating, it should work. Please tell me your drop and rear tire size too. Thanks.
J&S Sideyard Projects......we will be at...... Dino's 3rd annual Pre-ShowGit Down |
11-05-2010, 11:28 AM | #2 |
Re: Can I fit a 1.25 spacer on rear with Boss 20x10?
i used 1 inch off of ebay. 1.25 will push em out too far i bet.
horsepower sells cars torque wins races. "caroll shelby" |
11-05-2010, 02:10 PM | #3 |
Thanks for the input. What drop and tire size are you running? how much room do you have between the inner wheel well and back side of your tires?
11-29-2010, 01:17 PM | #4 |
Any other examples of people running Boss 20x10's in the rear? Adapter/spacer sizes?
11-28-2012, 04:54 PM | #5 |
Bump for more info.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
11-28-2012, 05:01 PM | #6 |
67-72 parts collector,…
I agree,... a 1" spacer would be better with the wide rearend.
1-1/4" to 1-1/2" for the early narrow rearend.
11-28-2012, 05:50 PM | #7 |
Old member
I'm running 1/4" spacer to clear inner fender with 20"x10" wheel.
11-28-2012, 09:27 PM | #8 |
What rearend you running?
11-28-2012, 09:29 PM | #9 |
Old member
12-01-2012, 01:14 PM | #10 |
