Old 11-05-2010, 11:49 AM   #1
irishfan77
rims and tires
Hey guys getting ready to get my chassis to roller status in the front. I need some help. I put a porterbuilt front end and changed my rotors to 5x5 bolt pattern. I have been to pull a parts and c/l and havent had luck finding rims because there were no 73-87 models to pull rims from. My question is, what other models of car can I pull rims from? Like 80's model impalas or vans? I figured you guys would know!! I only need steel rims for now just to move it around
As one door closes, another door opens!!
irishfan77 is offline   Reply With Quote
Old 11-05-2010, 11:58 AM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: rims and tires
below is some info for you....
see this link : http://67-72chevytrucks.com/vboard/s...d.php?t=234769
these are coming to mind:
1990-1996 Chevy Caprice
1994-1996 Chevy Impala
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-05-2010, 04:38 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: rims and tires
GM big car (Pontiac, Olds, Cadillac) always had 5 on 5 wheels, from the mid-50's. Problem is that they probably won't clear the rotors on the disc brakes. But, any GM big car from '71 and up (again, Buick, Olds and Pontiac) will have wheels that should fit. Impalas and Caprices from the same era may fit, but some may still use the 5 on 4.75 pattern. Of course, GM trucks from the full size lineup (71 thru '98) will have the right pattern. No 4WD GM wheels will work, but you already knew that.
Member Nr. 2770
Old 11-05-2010, 04:47 PM   #4
68Stepbed
68Stepbed's Avatar
Re: rims and tires
If you weren't so far away, I've got a set of rallies I'd sell ya.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
