11-05-2010, 12:08 PM | #1 |
Routing exhaust on slammed trucks
Hey guys I am looking for pics of how you routed your exhaust on your trucks that are on air. I have a bolt in notch and dominators with 2.5" drop spindles.. I just put the box back on and there isn't alot of room under there. I am running the air lines into the front of the box aswell. I have the CPP trailing arm cross memeber so I can run the exhaust through it..
Thanx Trevor
1968 short box stepside. 2007 5.3L 4L60, tuned w/EFI Live 2005 Silverado bucket seats. Dominator 2600's all around. Porterbuilt tubular control arms. Magnaflow 3" dual exhaust. |
11-05-2010, 06:37 PM | #2 |
Re: Routing exhaust on slammed trucks
11-05-2010, 07:27 PM | #3 |
Garage wrench
I don't have any pics yet but can get some. I just have stock exhaust manifolds to a cut down stock y-pipe to a magnaflow cat then a magnaflow muffler then a turn down before the rear axle. It sounds good but needs work as the y-pipe needs to be cut down more because it still hangs a little below the frame and looks like hell. I plan on having an exhaust shop do dual exhaust on it and dump them both before the rear axle. Simply because i'm not sure I can cut the y-pipe enough for it to tuck and not hit the engine/trans.
I just noticed you have an older truck so this may not help.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... Last edited by SBTork; 11-05-2010 at 07:28 PM. |
11-05-2010, 07:33 PM | #4 |
I talked to an exhaust shop and he said about $600, but will have to see the truck and how tight it is..
It is pretty tight right after the trailing arm cross member at full dump..
11-05-2010, 11:39 PM | #5 | |
needs more $$$
1970 2wd Blazer |
11-06-2010, 02:03 AM | #6 |
I'm running shorty headers with the pipes tucked up between the frame rails and through the trailing arm crossmember. My magnaflow mufflers are before the crossmember under the cab and I just dumped the pipes about a foot and a half behind the crossmember.
I dont like the looks of pipes out the back or sides but its louder in the cab. |
11-06-2010, 12:04 PM | #7 |
You wouldn't happen to have a pic of it...... What size of piping are you using?
11-06-2010, 04:21 PM | #8 |
ok, got another question. I am routing the 1/2" plastic air line and am wondering how close can it get to the exhaust and can you insulate it?. The exhaust will probably be 1 1/2" pipe, how hot will it get??
11-06-2010, 04:42 PM | #9 |
Sorry man, I don't have any pics of it. I used 1 1/2" pipe. All of my airlines are run inside of rubber hose for protection from heat, road debri, sharp edges,etc.
11-07-2010, 07:37 AM | #10 | |
http://www.summitracing.com/parts/THE-18051/ Here are some other pics of the exhaust from another thread. when the sun comes up, i will get better pictures of how low the exhaust sits when aired out. Last edited by dznucks; 11-08-2010 at 07:50 AM. |
11-07-2010, 12:03 PM | #11 |
Here are some pics of the truck aired out. In the 3rd pic and 4th pic, you can see the heat sleeving (blue) I used to protect the plastic lines from heat and chaffing. the LCA's and tranny cross member are the lowet part of the truck, but not by much.
11-11-2010, 11:37 AM | #12 | |
It's Better With Nitro
