need advice! Cab lifting
I need to pull the cab off the frame is it bad to run straps throught the cab our the doors ( wrapping a couple times) and lifing the cab with a tractor?
Will I shatter the glass? or flex the cab and screw it up? |
Re: need advice! Cab lifting
i would run the straps under the cab not thru the cab....my 2 pennies worth
Old Skool Club
![]() Join Date: Jun 2001
Had one on a trailer that we removed last week. We had used muscles and got it onto the trailer, but getting it off the trailer found us short of some pecs and abs. So, bring in the backhoe. The doors were off of it, but the glass is still in the front and back. We used a 4x4 that was wrapped with old towels. I'd recommend placing the "stick" as close to the windshield as possible, because the windshield and the firewall are going to be the heaviest parts of the cab and the most mass. If the "stick" is in the middle of the doorway, the cab will tilt with the rear glass going up and the firewall going down and the cab may come into contact with whatever your lifting it with if your chains/straps aren't long enough.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
I lifted my cab with 2 2x4s nailed together, ran threw the door windows and lifted it with a tractor. Didn't have any problems.
69 gmc 4x4 lwb 327 4sd not running |
It will bend the driprails"guess how I know". I have a 4x6 that I put through both windows with a 2 inch hole 2 inches deep.I then put a trailer ball on top of my engine hoist to lift it off.
Forever Grateful
I lifted mine with 2 2x4 's nailed together and ran them through the windows from side to side and lifted with a engine hoist
R.I.P Dad 04-07-42 - 05-27-09 |
Junior Member
I can't remember how many cabs we have lifted with a 4 by 4 strapped to the top of an engine hoist through the side windows located near the front without a problem. I think at least 6 for sure.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Got three buddys? Thats how I got mine off
1972 c-10 swb topless bagger project 2007 Acura MDX Tech (my daily driver) Build thread http://67-72chevytrucks.com/vboard/s...18#post4230818 |
Thanks guys!
Old Skool Club
However you choose to do the job....protect your back and watch your head!!
ENGINE BUILDER
Here's how I did it.
JIM ZAG |
![]() Join Date: Aug 2008
#13 |
yes, i do
check out thelonerife's Chuck's SWB Fleetside build thread. he built an adapter that goes on the end of his cherry picker that uses like a 4x4 through the windows. i think what i am gonna do is rig up some pulleys to the cross beams in my garage and use a come-a-long to hoist up the cab on my 72 when it gets some garage time
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
