Old 11-05-2010, 01:48 PM   #1
cpisani70@aol.com
cpisani70@aol.com's Avatar
1 wire Alt
Got rid of my three wire alternator and voltage regulator to upgrade to a 1 wire chrome alt.Question is what do i do to wire it correctly and have the guage work.Is the brown wire from the reg. the wire that works the guage if so do i just tie that together w the red wire from the alt??? Oh the truck is kinda a 1968 K-10??
cpisani70@aol.com is offline   Reply With Quote
Old 11-05-2010, 02:49 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: 1 wire Alt
Just bolt it on and hook the large red wire to the back of the one-wire alternator .
You're battery gauge wiring has nothing to do with the type of alternator. It is wired into the battery circuit and the regulator circuit and measures the voltage differential between the alternator and the battery/. One post of the gauge is wired to the red wire off the battery that goes to the junction on the right passenger fender. The other post goes to the red wire junction that comes off the voltage regulator.
The reason the gauge doesn't work is probably because one of the two 4 amp fuses in the circuits above is blown. You can find these in the harness between the battery and the voltage regulator that runs over the radiator support. and the other one should be in the harness that goes to the firewall connector . Look for a small football shaped holder in the harness. The diagram below shows the fuses but not there locations .
Name:  HEI and stock wiring..jpg
The fuses are in the vertical wire on the right side of the diagram and in the horizontal wire near the bottom center.
The grown wire you asked about will not be needed with a one-wire alternator but should you change to a three-wire type later you will need it so don't just cut it out of the harness. Leave it plugged in and unplug the regulator.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
