11-05-2010, 02:02 PM | #1 |
Hei
68 K-10 upgrade to HEI what do i feed this dist. with i have heard the original wire doesnt supply enuff voltage can anyone help with this?
11-05-2010, 02:21 PM | #2 |
Msgt USAF Ret
Re: Hei
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-05-2010, 04:21 PM | #3 |
Re: Hei
This topic has many threads that will help you here is one.http://67-72chevytrucks.com/vboard/s...ad.php?t=13698 You can also do a search and find so much info on HEI that it will make your head spin. Always check the FAQ section the information is endless!!!
11-05-2010, 08:57 PM | #4 |
Re: Hei
Massachusetts checking in. This group also helped me correct my voltage on my converted HEI. Friends outside this group cannot believe the support our group offers. Good luck
11-05-2010, 09:05 PM | #5 |
Re: Hei
I run a 10-12 gauge wire from the fuse block to the HEI. Any switched 12V will work. Double check that it's hot in start, not just run. And triple check that it's not a constant 12v, that will fry the coil.
Derek 72 Chevy Cheyenne Super LWB 454 SS LS6 90 GMC Suburban V2500 350 ----------- 64 Chevy El Camino 357 73 Jeep Wagoneer 360 78 Jeep Cherokee 360 79 Scout II 345 88 Jeep Wrangler 4.2L 91 Jeep Wrangler 4.3L 98 Lincoln Mark VIII 4.6L 01 GMC Yukon 5.3L "If it's not broken, fix it 'till it is!" |
11-05-2010, 11:14 PM | #6 |
Re: Hei
I just did my truck. with it in the run postion you only get 6-9 volts i can not remember well. Was a yellow wire. I followed it back and in the plastic above the firewall it came together with another yellow wire and turned in a piece that look sort of like glass coated wire used in high heat places. I cut it back to there and seems the resister was somewhere in there cause i started reading 12 volts at the end of the wire. So spliced from that point to the wire i cut off when i got my hei from the yard i was at. My truck is a 68.
11-06-2010, 12:08 AM | #7 | |
Msgt USAF Ret
Re: Hei
