Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 11-05-2010, 03:05 PM   #1
snaus32
snaus32's Avatar
4.3l swap
Hey guys i need some help my nephew has a 98 sonoma 2 wheele drive with a broken frame but good 4.3l with engine code X. He just picked up a 96 s-10 4-wheel drive thats really not in bad shape but has blown motor 4.3l engine code W is it possible to just swap these motors or are they different?
also do you think there will be a diference in wiring and computors?
snaus32 is offline   Reply With Quote
Old 11-05-2010, 03:56 PM   #2
spudz
spudz's Avatar
Re: 4.3l swap
swap em
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 11-05-2010, 05:38 PM   #3
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Re: 4.3l swap
Yea buddy, should be a good swap. I have a junked 96 s10 4.3l so if you break anything lol let me know.
Brandon...
"IT ONLY TAKES EVERYTHING YOU GOT!!"
Semper Fi
Chevy350V8 is offline   Reply With Quote
Old 11-05-2010, 05:47 PM   #4
ofnaman
ofnaman's Avatar
Re: 4.3l swap
Should be the same engine/fuel injection system. I've alway's wandered what the difference is between the w and x. I have had both apart, but cant find any differences.
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 11-05-2010, 05:53 PM   #5
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Re: 4.3l swap
Maybe Manufactured in a different place idk...
Brandon...
Semper Fi
Old 11-06-2010, 10:11 AM   #6
snaus32
snaus32's Avatar
Re: 4.3l swap
from what i found online the only difference is intake and about 10 hp lol
Old 11-06-2010, 06:52 PM   #7
ofnaman
ofnaman's Avatar
Re: 4.3l swap
I know the later year 4.3's used injectors at the end of the fuel lines on the spider, instead of the earlier design that had poppet injectors in the injector block with spider lines to the nossles. Maybe that is the difference. I know gm makes an upgrade kit to convert the earlier design to the later design.
Old 11-08-2010, 01:58 AM   #8
ofnaman
ofnaman's Avatar
Re: 4.3l swap
Found this on s10 forums.com:
1996 - 1998 VIN "X" WITH BALANCE SHAFT: The VIN "X" engine replaced the VIN "Z" in '96. It is identical to the '96 VIN "W" engine except for a milder cam and 10 less horsepower. The cam is a p/n 10241692.
1996 - 1998 VIN "W" WITH BALANCE SHAFT: The VIN "W" engine has a 10541691 camshaft and makes 10 more horsepower than the VIN "X" engine. There is also a special roller cam for the VIN "Z" turbocharged engines (p/n 10214714) along with a couple more with a fuel pump lobe for marine and industrial applications, but these are the common ones that were used in most of the cars and trucks. All of these cams can be identified by the last three digits of the part number that is stamped on the barrel of the cam, just behind the last lobe and in front of the distributor gear.
Old 11-08-2010, 11:06 PM   #9
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 4.3l swap
The extra 10 HP went into four door Blazers and Jimmys.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-09-2010, 12:32 AM   #10
ofnaman
ofnaman's Avatar
Re: 4.3l swap
My reg cab shortbed '96 s10 has a "w" engine with the 10 extra hp. I think it was kind of the luck of the draw.
Old 11-27-2010, 04:45 PM   #11
BIG10
BIG10's Avatar
Re: 4.3l swap
That should be an easy swap. They are practically identical. Let us know how it goes.
Jay
1978 Big 10 Silverado, 355 + 700R4 + 3.42 + factory tach + A/C + dual tanks + working cruise control = awesome highway cruiser.
BIG10 is offline   Reply With Quote
Old 12-20-2010, 02:56 AM   #12
chevyndn
Re: 4.3l swap
i thought that the bell housing were different.... but i may be mistaking.
chevyndn is offline   Reply With Quote
Old 12-20-2010, 09:32 AM   #13
Tink
Tink's Avatar
Re: 4.3l swap
Bellhousings are the same... they were different on the 60 degree V6, the 2.8L.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 12-27-2010, 07:02 PM   #14
bobwires
Re: 4.3l swap
did they offer W and X engines till '02? do I have that right? I was thinking '03 was when they changed them again
I'm on the hunt for a 4.3 for my '97 blazer, and the location is what's killing me. anybody in the extreme NW US with one?
thanks
bobwires is offline   Reply With Quote
Old 12-28-2010, 01:22 PM   #15
Damien
Damien's Avatar
Re: 4.3l swap
You will have to swap the oil pans. The 4x4 pan has clearance for the front diff.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
