Old 11-06-2010, 07:58 AM   #1
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Question Parts Interchangable?
1967-1970 year model Truck & Suburban.
Does anyone know if the passenger door from a 1969/70 door would work on the rear passenger on a Suburban?
Or are we talking about two different animals here and can not be swapped?
Another one is can this same 69/70 door be used as a regular passenger side door on the 1967 Suburban?
Thanks!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 11-08-2010, 07:20 AM   #2
C20-67_N_MO
Re: Parts Interchangable?
ttt
Old 11-08-2010, 07:28 AM   #3
First question:no.The Suburban rear side door is unique.
Second question:yes.But,the only difference is in the window frame.That can be swapped.you can convert a Suburban door to a truck door and visa-versa.
Old 11-08-2010, 05:36 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
its not a nut and bolt job, welding is needed.
So the quick and easy answer is no.
Old 11-09-2010, 05:41 PM   #5
C20-67_N_MO
Question Re: Parts Interchangable?
But from a '67 truck to '67 'burb there should be no problem, right?
Plus rocker panels etc from same year model.
Old 11-09-2010, 05:54 PM   #6
jay6891
Car Knocker
jay6891's Avatar
Front doors window frames on any year model sub are different from any year model pickup. Subs are squared off at the back, pickup are rounded. Rear door on any model sub is smaller, ie, narrower than pickup or front door Sub. Frames can be swaped on front doors to make work but you will need to cut and reweld. Hope it helps.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 11-09-2010, 09:00 PM   #7
C20-67_N_MO
yup.
Clears things up crystal clear for me.
Thanks.
