Old 11-06-2010, 09:31 AM   #1
81ratrodc10
house of chevy's
81ratrodc10's Avatar
starting problem?????
so this is the first time this has happened i dont know what to look at first i went to a buddys house last night truck was running fine no issues turned it of got out then they needed me to move my truck to a different spot got in turned the key ther was nothing no clicking starter noise nothing so i figured it was the fuse that i had to chenge last time looked at it it was fine so i decided to enjoy the rest of my night went out side like 2 hrs later for ****s went over to the truck to c and it started perfectly fine hung out some more started it to come home got home turned it off tryed starting it again and nothing again i dont know if its the starter or siloniod what do you guys think
thanx
1987 m1028 cucv d30
2001 chevy s10
2000 honda shadow sabre 1100
"it's going to be an interesting ride home"
81ratrodc10 is offline   Reply With Quote
Old 11-06-2010, 02:07 PM   #2
irishman999
irishman999's Avatar
Re: starting problem?????
I say loose connection. Start on the battery terminals, clean them good with a wire brush. After that check the cables going to the starter as well as ground cables.
irishman999 is offline   Reply With Quote
Old 11-06-2010, 06:37 PM   #3
81ratrodc10
house of chevy's
only one come on i need more help lol
1987 m1028 cucv d30
2001 chevy s10
Old 11-06-2010, 07:40 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
If it's only doing it right after you shut it off, could be the solenoid getting hot.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 11-06-2010, 08:31 PM   #5
WestButteTruck
Kung Fu Master
WestButteTruck's Avatar
Start here with the basics first.
72 GMC SuperCustom 4x4
1972 Chevrolet Cheyenne Super 4x4
WestButteTruck is offline   Reply With Quote
Old 11-07-2010, 07:52 AM   #6
tucsonjwt
In my experience, the following were replaced when I experienced this problem:
ignition switch
neutral switch
stater/solenoid
What it needed: upper steering column rebuild.
Very expensive guessing on the part of many "highly qualified" mechanics.
tucsonjwt is offline   Reply With Quote
Old 11-07-2010, 08:30 AM   #7
irishman999
ignition switch
neutral switch
stater/solenoid
Keep in mind im not a mechanic, its just a forced hobby I have. I could be completely wrong but this is just my common sense.
Ignition switch- Sends a signal to a Relay that will power your starter, Its just a switch so as long as its sending power to the relay the switch is working (as long as you hear clicking).
Neutral switch- That should just complete the electric circuit needed to send power to your starter, once again if you hear clicking that means it is functioning and the starter is getting power.
Starter solenoid- I was under the impression when this did not work it would just kick over the starter motor without engaging the flywheel, making a zinging sound.
9 out of 10 electrical problems seem to be a bad ground. Thats exactly where I would start, making sure all your cables have good connections. All the cables.
Old 11-07-2010, 10:38 AM   #8
James McClure
One shot, one kill.
I spent 33 years working for Chevy dealers all over upstate NY. This may really sound "backyard", but in the interest of speed, this is the way alot of us checked this problem. First we checked the B+ circut, then B-. Next, hook a test light to the purple wire at the starter and turn the key to start. If it lit, solinoid feed circut was good. If it didn't, backtrack up to the ign switch testing at each switch in that circut. Next (and this is the backyard part) have a buddy sit in the truck (or car) and hold the key to the start position, while he is doing that, give the starter a good whack with a hammer. LOL If this works, and it usually does, rebuild\replace the starter. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 11-08-2010, 12:26 AM   #9
mooseknuckles
mooseknuckles's Avatar
My old Z28 used to do that at the worst possible times! turned out to be a bad fusible link on one of the starter wires.
mooseknuckles is offline   Reply With Quote
Old 11-08-2010, 05:55 PM   #10
81ratrodc10
house of chevy's
i checked all the wires they seem to be okay i have power from battery to other things that are hooked up but now im thinking it might be the ignition switch cause i have no power for any thing that the key controles ie wipers radio how hard is it to change like tucsonjwt said would the nuetral saftey switch affect any of that thanx
1987 m1028 cucv d30
2001 chevy s10
Old 11-08-2010, 06:30 PM   #11
dabels23
dabels23's Avatar
I had that prob. on my 72. Would only do it when it was warm all my wires cables looked and tested good. Then one day after running around town and it was really warm I popped the hood and the neg battery cable was SMOKING it looked fine, but when I took it off it fell apart.
dabels23 is offline   Reply With Quote
Old 11-09-2010, 07:39 AM   #12
81ratrodc10
house of chevy's
is it worth changing both at the same time
1987 m1028 cucv d30
2001 chevy s10
Old 11-12-2010, 06:27 PM   #13
81ratrodc10
house of chevy's
so i picked up a new ignition switch today going to put it in tommarrow hopefully that is what the problem is i guess well have to wait and c
1987 m1028 cucv d30
2001 chevy s10
Old 11-13-2010, 01:10 AM   #14
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
My Blazer used to do the exact same thing. Look at the wires on the junction block on the firewall. Make sure they are clean. Mine would start right away with only a wiggle of the wires that attach at the junction block. I never did fix that before I sold the truck.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 11-13-2010, 10:10 AM   #15
vtwinsport
vtwinsport's Avatar
The neutral switch will affect everything. Mine did that last month. No radio, lights, fan, anything. I bypassed the switch. 2 puple wires going down the cokumn near the firewall to a plastic assembly. pull the connector off, cut each wire and put a wire not on them and put a few wraps of tape around the nut on to the wire (so it don't fall off). That should do it.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 11-13-2010, 01:04 PM   #16
81ratrodc10
house of chevy's
so i went out this morning and changed my ignition switch tightened my fuse box cause it was loose put it all back together still nothing so i decided that when it happened last time it was a fusable link so i thought may be the other three were bad ran to parts store bought three new ones changed the first one and it fixed the problem again so now im happy my truck starts again lol
1987 m1028 cucv d30
2001 chevy s10
