Old 03-03-2003, 12:31 AM   #1
robby
Semper Fidelis
robby's Avatar
steering box interchange?
Can I use later model power steering box on a 69-70 GMC K10 that doesn't have power steering now?
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
Old 03-03-2003, 01:50 AM   #2
Mudder
Mudder's Avatar
I believe they are the same but you may run iinto problems with the rag joint splines. Some had different slpines and were different sized shafts.
Mudder is offline   Reply With Quote
Old 03-04-2003, 12:01 AM   #3
robby
Semper Fidelis
robby's Avatar
Thanks Mudder, would it work if I left on the rag joint from the later model box?
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
Old 03-04-2003, 12:04 PM   #4
red450ih
red450ih's Avatar
Any 73-87 PS box will bolt up. Just use the rag joint that comes with the box. Somewhere around 78 they have a smaller imput shaft (where rag joint goes).
Keith
GMC
red450ih is offline   Reply With Quote
Old 03-04-2003, 12:11 PM   #5
Mike C
Mike C's Avatar
Also, sometime in the early 80's they switched from flare fittings to o-ring fittings on the hoses. You will have to get a matching pump or change the rear fitting to match the box. (Or have custom hoses made)
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-04-2003, 09:10 PM   #6
robby
Semper Fidelis
robby's Avatar
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
