Old 03-03-2003, 12:32 AM   #1
robby
Semper Fidelis
robby's Avatar
4x4 steering gear interchange?
Will a later model steering box work on a 69 or 70 GMC K10?
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
Old 03-03-2003, 10:28 AM   #2
JimKshortstep4x4
Talking
I know that the 4x4's up through 78 will directly interchange. I am not sure after that, but they can be made to work.
Jim
Old 03-03-2003, 10:38 AM   #3
Pont
I need another Barley Pop
Pont's Avatar
Like Mudder said on the 4X4 board, you may have an issue with rag-joint splines but it can still be done relatively easy. As far as mounting goes, it will bolt directly to the frame. If you ever consider building a crossover steering setup, make sure you get a late model 2wd steering box with pitman arm.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 03-04-2003, 12:02 AM   #4
robby
Semper Fidelis
robby's Avatar
Thanks, I'll ask here too. What if I just leave the rag joint on the later model box?
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
