Fuel sender wiring question...
I have a fuel cell with a 90ohm fuel sender in it with a "G" and "S" on it, I think..... I have two wires coming out of my cluster plug- fuel gauge feed and fuel gauge... How do I wire this correctly? I think "S" goes to "fuel feed", "G" goes to ground, but not sure about the "fuel gauge" wire.... I dont know.. my brain is mush right now!!!
My truck didnt have a working gas gauge when I got it, and the wiring was a mess. Im almost done with installing the EZ (yeah right) harness in and the gas gauge is the last thing I need to do. Since the truck was in such bad shape, I dont have a good reference point to go back to. Thanks! |
Re: Fuel sender wiring question...
what color are the wires? the power is plugged into the fuse box (labeled fuel gauge)on mine.
![]() Join Date: Jun 2009
"S" is you signal wire from the gauge it should be tan with black strip and "G" is ground you can hook it up anywhere where there's a good ground location.... thats what i did on mine anyways......hope this helped
#4 | |
On my notes, which may be wrong.. I show on the pin out gauge cluster plug- #3= Fuel Gauge Feed, #4 Fuel Guage..... Where does #4 go? Wire color isnt work in this case, my new harness is all black, only the small pig tails from my cluster plug remain... |
are you sure it is not supposed to be power from the fuse block? Does the gague already have 12 volts?
Man I also feel your pain sometimes in frustration things get confusing. Last edited by id_unavailable; 11-06-2010 at 06:27 PM. |
Not yet, Im getting there.... I will try wiring it up and see what happens... Im sure I will figure it out. I have been working on my vent window seals today- took a break from the wiring. Brain is not as mushy now I think I can get it tomorrow....
GM's designations can be confusing because I have seen them use "fuel gauge" for both the dash and tank units. All I can tell you is that the dash unit lead which DOESN'T go to the tank goes to ignition switched power. If you have stock wire colors, that wire should be pink.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. Last edited by raycow; 11-07-2010 at 11:57 AM. |
#8 | |
thanks for the help! ![]() |
According to my Painless instructions that pink wire goes from Gauge to sending unit and the gauge gets its power from the B+ wire from fuse panel to gauge. B+ should be a red/white wire
69 Chevy 4x4 383 Power ![]() Last edited by haysonj; 11-07-2010 at 01:44 PM. |
#10 | |
I don't know about you but I wouldn't want 12 volt power from the fuse block going to my gas tank with gasoline in it. ![]() In my 72GMC I have one wire going from the gas tank sending unit to the fuse block marked "Fuel Gauge" or something like that. No power wires and no ground wires.
-Scott- Last edited by sjarrett71; 11-07-2010 at 01:49 PM. |
#11 | |
69 Chevy 4x4 383 Power ![]() |
