Brake light/park light troubles
Ok I am so confused I had checked everything I can think of......I have no turn signals and when I push the brakes the brake lights and the front park lights come on..Now everything worked just fine the other day then they just quit..I replaced the headlight switch and the brake light switch thinking they may be a problem but it did nothing.....What could be wrong or what do I need to check to find the issue....
"If it throws you back in the seat when it shifts, it was slowing down before it shifted" ![]() ![]() 1992 Chevy 1/2 ton 4x4 wore out 350 1975 Chevy 3/4 ton 4x4/ 8" suspension lift/ 468 Big Block/ 4 speed/ 4.56 gears/ 17' American Racing simulated beadlocks with Pro Comp 37x12.50 tires 1950 Pontiac Chieftain Straight 8/Hydromatic tranny |
Senior Enthusiast
Re: Brake light/park light troubles
Random problems like this are most frequently caused by bad grounds. The simplest solution is to run a separate ground wire from each light bucket to the frame. The factory depended on sheet metal connections for ground on many circuits, and 4-5 decades of rust/corrosion and paint can play havoc completing the electrical return. The other main switch you haven’t replaced is the dimmer switch. Although the switch rarely fails, in some of these trucks they suffer a lot of moisture and corrosion and can be the source of bad connections.
Also here are some other earlier threads dealing with lighting issues: http://67-72chevytrucks.com/vboard/s...t=brake+lights http://67-72chevytrucks.com/vboard/s...t=brake+lights http://67-72chevytrucks.com/vboard/s...t=brake+lights http://67-72chevytrucks.com/vboard/s...t=brake+lights http://67-72chevytrucks.com/vboard/s...t=brake+lights http://67-72chevytrucks.com/vboard/s...t=brake+lights |
Well added ground wires to every light and still nothing......So i toreinto my column and as it turns out my turn signal switch's contacts were dirty. Cleaned them and eveything works great again....
Electrical Problems. Ya got'a luv'em, cause candles just won't stay lit, even on an inline 6.
Ya got to love electrical gremlins...and in my 65 panel I need all the lights I can get....These things have a huge blind spot...
