tobins 52 gmc
french head lights
thinking about doing french lights on my truck ,need help on finding a sourse for a kit and if anyone has pic and any info on installing them please let me know .
Re: french head lights
There is this style of kit which I believe can be addapted to many years.
http://www.thehoffmangroup.com/autol...renchheadlight And then there is the do it your self way by using 52-54 Mercury headlight rings. They are steel so they can be welded solid. http://rodcustom.automotive.com/1330...hts/index.html It all depends on the look you want to achieve. Kim Last edited by Kim57; 11-06-2010 at 08:03 PM. |
Lost amongst the CORN
Am doing a 49 truck and always loved the look of frenched headlights. The first style is made by Hagen, IMO once you see them in person you realize they look cheap. Just the style I guess, just doesn't look good.
Currently working on How To Videos and custom metal 70 Chevelle gettin Sliced and Diced Anything But STOCK 70 Chevelle SS455 not a typo its a BUICK BABY 49 and 72 Chevy Trucks restored to original...close to it Drommer Stor....Norwegian for Dream Big http://s969.photobucket.com/albums/a...lle/?start=all https://www.flickr.com/photos/47922830@N03/ Pictures of my work and projects |
#4 | |
![]() Join Date: Mar 2007
Here are a few pics.. ![]() ![]() ![]() ![]() ![]() I impressed myself, as I had more pictures than I thought... ![]() Good luck Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 Last edited by youngrodder; 11-07-2010 at 09:45 AM. |
[QUOTE=youngrodder;4281924]I went with a Hagen kit. I think that frenched headlights really help the look of these trucks. The instructions were good and fairly straight forward to install.
Where are the adjusters on the Hagen kit? I was not impressed with the Hoffman kit!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#6 | |
[quote=solidaxel;4282023]
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
Marc, by the look in your pictures you have welded your pots on the outside of the fender, correct?
I am looking at mine and wondering if the lip should be welded from the inside of the fender or the outside? Also, did you wait till the fenders were bolted on to the body etc. like the say to do in the instructions? Or is it that critical for alignment? Also, how did you find the welding? I am concerened about the heat and warping. Will do spots all around and keep building from there. Thanks. Mark |
"Trucks" on Powerblock actually frenched a set of headlights on the "Classix" project. The video is free on-line at powerblocktv.com. Go to the full episodes section for Trucks, I think it was done in 2010.
#9 | |
4Dseven- I welded mine on the outside (I didn't weld mine at all from the back side). I didn't have any issue with warping. Just took my time and spaced each tack weld. I did not install mine with the fenders on the truck but I did wait to drill the mounting tabs until after the fenders were on. If you were carful you could do it with the fenders off the truck. Good luck Marc
I used my stock headlight rims, welded to the fender. I mounted the buckets on the back ,old school style.
#11 | |
[quote=youngrodder;4283242]
Night Prowlers is selling reproduction 52/54 Merc headlight rings http://www.shop.thenightprowlers.com...r-5254merc.htm They do take a bit more work to get right on an AD truck but the final appearance is well worth it. |
mr48Chev
I checked out the link. Those aren't bad. What I like better about the Hagen is the angle/size of the chrome flange. They make the whole light look bigger which I think helps with the proportions of the fender. A person can always get them in a paintable option if the chrome flange is too much. To each their own....it's all good. Marc
#13 |
I am in the process of doing a Hagans kit right now. I have a couple of pictures on my build thread.
Bernie |
#14 |
kim57 posted this link....so...what keeps tension on the screws just the spring? it looks like it can just slide back out of the pot..or at least vibrate..
http://www.rodandcustommagazine.com/.../photo_17.html I was thinking close to the same thing...but just drill a hole in the bucket...slot the original screw. and just use a small screwdriver to reach in the hole and adjust the original adjusting screwfrom behind? Last edited by skip99; 03-05-2012 at 11:59 AM. |
