Door Speaker Hole Repair
I'm sure I'm not the first to make this repair but it turned out so good I wanted to share it with you. I have 0 body working skills so if I can do this anyone can.
This is the passengers side door on my 65 C10 project. ![]() I cut the hole square because it is easier for me to make a square using a cutoff wheel than a circle. ( While I had the bottom of the door open I put in the sound deadening mat. I also found that there is a support brace inside the door if you go much further forward. ![]() I used the bottom off a doner door that was rusted beyond repair. ![]() I used the back end of the doner door to replace the front end of my project door. The panel reliefs will match up you just have to make sure that you find the center line of both relief panels and that measure back on the doner panel the same distance as the leading edge of the hole on the project door. ![]() It took a little sanding to get a good fit and I use these leveling tools I got for Eastwood to match the patch to the door. ![]() I used a Mig welder to weld out the patch ![]() A thin coat of body filler to smooth everything out ![]() and some primer and spray paint and ALMOST like new
For zero body working skills you did a great job...plus other people learn from the explanation and pictures.
Bob |
Re: Door Speaker Hole Repair
Great job! I have to do the same thing soon. Pictures helped out tremendously.
Who Me?
Looks great!!
Steve1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
![]() Join Date: Aug 2008
Cool- good job
good job
Senior Enthusiast
Nice repair and a great show and tell. Thanks for posting.
CLASSIX Truck Club
Hey, I think it looks great. Some guys try and repair cut holes made from crazy truck owners, and some guys are still cutting up their dashes and door panels. It's a shame to cut up these trucks.
Good job.
Looks great
Bad Decisions usually make for Good Stories. |
I have the same situation, just picked up two junk doors for the panels plus I guess whomever owned this truck before me had cut the opening larger to access removel of the window crank with a torch
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
| Bookmarks |
