Old 11-06-2010, 08:44 PM   #1
wlevick
What works best to cut dash to install radio?
Well...finally decided to cut a hole in my dash and install a CD player. (Got to have music if I am going to be a "Long Hauler" on the 2011 Hot Rod Power Tour !) What is the best saw to use? I tried my Dremel today with a diamond tip wheel - but did not like the results.
wlevick is offline   Reply With Quote
Old 11-06-2010, 08:53 PM   #2
losthope
losthope's Avatar
Re: What works best to cut dash to install radio?
i know theres a post on here somewhere where someone here makes a slick looking bracket that mounts cd player in glove box and still able to put paper work inside to..but i always just put mine in glove box in all my old cars i just cant see cutting up a dash but each to their own..id try a metal cut off blade in a grinder should cut right through with a couple lines drawn and a steady hand.
losthope is offline   Reply With Quote
Old 11-06-2010, 08:57 PM   #3
losthope
losthope's Avatar
HERES THE LINK
http://67-72chevytrucks.com/vboard/s...glovebox+radio
Old 11-06-2010, 09:02 PM   #4
wlevick
Thanks...but, to late for the slick glove box mount. I already started cutting. Now I need to finish it and make it look good!
Old 11-06-2010, 09:41 PM   #5
fryer1979
Redneck Hillbilly
fryer1979's Avatar
meh, it's only metal. I use my air saw with a small metal blade. Slow and steady for a nice clean and straight cut. Having a marked outline for the hole you need is a big help. I've used my RotoZip a time or two with a metal bit, but it is a bit too aggresive for my taste (a little too easy to let get away from you).
fryer1979 is offline   Reply With Quote
Old 11-06-2010, 10:13 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
I use the Dremel EZ Lock cutter for virtually all of my sheet metal cutting up to 1/8" thick. The discs are very strong, last a long time and are easy to change without a screwdriver. You just pull down on the collar and swap out the disc. They are also very thin, resulting in a cut about the width of a hacksaw blade.
Amazon.com: Dremel EZ406 1 1/2-Inch EZ Lock... Amazon.com: Dremel EZ406 1 1/2-Inch EZ Lock...
I find they work best when using a foot controller, so you can set the tool on full speed and use both hands to control the cut. If I were doing something like a dash, I’d drill the four corners first, then slice between the corners. This leaves nice smooth corners and avoids the risk of cutting too far.
Old 11-06-2010, 10:16 PM   #7
Ackattack
Ackattack's Avatar
pneumatic body saw
http://www.northerntool.com/shop/too...ct_22114_22114
Ackattack is offline   Reply With Quote
Old 11-06-2010, 10:24 PM   #8
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Originally Posted by Ackattack View Post
That's the one I was referring to, actually I think that is the one I have.
Old 11-06-2010, 11:49 PM   #9
blackedoutharley
This one is a lifesaver for doing the job.
http://www.northerntool.com/shop/too...ct_22264_22264
blackedoutharley is offline   Reply With Quote
Old 11-07-2010, 08:52 AM   #10
Born Lucky
I just did my dash for a radio install.
I tell you that the decision took awhile because I did not know if I wanted to cut up the dash.
The tools I used were masking tape, a sharpie, a dremal like tool, and several files.
First I layed out my pattern(measure,measure) then I applied my cut off wheel( I liked the smaller wheels because of less sparks) then I filed to fit.
I tell you that with patience you will make it look clean and professional.
Born Lucky is offline   Reply With Quote
Old 11-07-2010, 08:56 AM   #11
72freak
Rottenwood Garage Member
72freak's Avatar
Thanks...but, to late to make it look good!
Agreed!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 11-07-2010, 11:32 AM   #12
Chevy Fleetside
Chevy Fleetside's Avatar
I think I used an air body saw but I might have just used my jig saw with a metal blade in it. Heck it was about 8 years ago I did this.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 11-08-2010, 07:24 AM   #13
wlevick
Well...it's done. I used one of the Dremel "EZ Lock" blades and a file. Worked like a champ. Thanks for the help.
Old 11-08-2010, 09:15 AM   #14
lakeroadster
Looks like it was meant to be!
The 64-66 dashes have rectangles all over them, the more modern radios just look correct, more so than the oem radios, IMO.
lakeroadster is offline   Reply With Quote
Old 11-08-2010, 09:32 PM   #15
Chevy Fleetside
Why thankyou John.
John
Old 11-08-2010, 11:01 PM   #16
TopFuel1966
TopFuel1966's Avatar
The more modern radios just look correct, more so than the oem radios, IMO.
............and they work a lot better,too.
TopFuel1966 is offline   Reply With Quote
