11-06-2010, 09:13 PM | #1 |
Fuel Gauge
Ok, so after putting in a new dash and tach, i went to start it,and after having it run for a while, i noticed that the needle was pegged way past full. so after flipping the tank selector alot and looking through the wires and such, im kinda at a loss. i've browsed thru the older posts and couldn't find anything. and i know it worked an hour before, well cuz i was using then. So any input would be appriceated!
Thanks, Cole
1970 Chevrolet custom camper 20 2000 F@$d F250 Powerjoke "And i still like bologna on white bread now and then" -Alan Jackson |
11-07-2010, 12:49 AM | #2 |
Desert Rat
Re: Fuel Gauge
I had the same issue after installing a carburetor. The gauge itself may be bad, or perhaps a round plug on the firewall just to the driver's side of the intake manifold may have come unplugged. That was my problem.
Other than that, maybe there is an issue with the printed circuit? I'm sure someone else will chime in with further advice. |
11-07-2010, 09:41 AM | #3 |
78K & 79C Jimmys
Re: Fuel Gauge
that usally is the sender unhooked
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
11-07-2010, 10:36 AM | #4 | |
Re: Fuel Gauge
good luck
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ Last edited by vtwinsport; 11-08-2010 at 12:48 AM. |
11-07-2010, 07:11 PM | #5 |
Re: Fuel Gauge
Turned out that i had just loosened the plug in the firewall. simple mistake of mine, but thank you!
11-07-2010, 10:55 PM | #6 |
Salty Sailor
Re: Fuel Gauge
lucky, i had to drop my tank and re-attach a ground wire to get my gas gauge to stop lying and saying it was past full hahahaha
86 c-10 Custom Deluxe Savannah, Georgia |
11-08-2010, 01:53 AM | #7 |
Desert Rat
Re: Fuel Gauge
