6-8 Drop with 18&20's
Anyone got pics of that setup? I am thinking about that drop and wheel combo for my 68.
Re: 6-8 Drop with 18&20's
Is that an actual drop? That's pretty low.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
ive heard of and am doing 5.5-7 drop but not a 6-8 ? not sure what would rub?
94 ls swap silverado 65 Pontiac 78 c30 crew cab dually (parted and gone) 82 c30 crew cab dually ( now building ) 91 r30 crew cab dually (parted and gone) 69 swb-sold 71 lab sold all in progress......__ ..........._______ |__\__ ..........|__(O)______(O)] ........................ |
Just my opinion but different size wheels is UGLY. I think it kills a truck altogether. Do one size all around.
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 |
67-72 parts collector,…
![]() Join Date: Nov 2002
I have a 5.5/7.5 on my red 69 swb.
The only way I get away with it,... I'm still running 15" wheels. (215/70 and 275/60 tires). I still have my inner fenders installed, and they are real close. Turning the front set of 18's or 20's would be the issue, unless you run a really short tire. Air bags would fix that, but I'm sure you would have issues with a static drop. Posted via Mobile Device
not possible with big wheels you will have issues, if you want to go that low as already mentioned go with air bags...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
here is my 5/7" with staggered 20's with 245/40/20 and 275's rear. slight BFH mod in the front inner fender and no problems
#8 | |
Master Procrastinator
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
#9 | |
The front should be fine, I know there will have to be a notch for the back but I think the pumpkin wont hit the bed. I had a 4-6 on my 67 with no notch so I am pretty sure the 8" will work with a notch..... maybe someone will chime in.
#13 |
#14 |
#15 |
#16 |
I have a 5.5 drop on the front of my truck running 22 in rims with a 305/40/22 tire.
#17 |
![]() Join Date: Apr 2005
Perfect stance! Did you add shims to correct your driveshaft angle? If so, what size?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#18 | |
I've only driven it twice since I installed the drop. It seemed fine. It's been in storage ever since. (I have too many projects) Sorry I'm not much help.
#19 |
A 245-45-18 is around 26.5-ish. That's a good match for 295-40-20's on 10" rear wheels @ 29.25-ish. That's what was on my 74.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-18-2010 at 01:04 PM. |
#20 |
needs more $$$
Got any pics of this?
1970 2wd Blazer |
#21 |
Junior Member
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#22 |
Big Red - Now its a SWB!
I'd like to see pictures as well, I have the same size on my 01 tahoe and I'd like to run some on my truck but figured they'd be too big with that much of a drop.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#23 |
just for reference the 305/40/22's are 32" tall and 12.5" wide.
#24 |
Exactly..... 32" tall does not equal a low ride unless it's CUSTOM.
#25 |
I have to resize the pics but I'll try to get them up tomorrow, latter today. The truck has a nice stance and the only interference is I lost a little in my right turn as the wheel hits the power gear box, but it is a minimal loss.
