Old 11-06-2010, 10:58 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Identify these tires!
What tires are these?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 11-07-2010, 10:47 AM   #2
desertrat
desertrat's Avatar
Re: Identify these tires!
BFGoodrich Project T/A
These are a non DOT approved desert racing tire that you will find on a lot of trophy trucks, class 1s and pre-runners.
They say Baja T/A on the side but I believe if you purchased a set a Baja T/As you will not get the exact same tire.
Also not that the tire you posted has been grooved
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris
desertrat is offline   Reply With Quote
Old 11-07-2010, 11:38 AM   #3
thirdstreettito
Resident of Here
It isnt the baja t/a, look at the treads. I've seen this tire before but I dont remember what it is.
~Bradley~
Miss having a truck
Old 11-07-2010, 04:42 PM   #4
desertrat
desertrat's Avatar
The only thing I can see different on these is the center lugs are wider. It is either an old pattern or a set that was made for testing and he got his hands on them.
Old 11-08-2010, 09:04 AM   #5
BFG Project T/A off road use only.
Old 11-11-2010, 10:17 PM   #6
dlhughes2005
^x2 on the bfg's!
85 GMC SWB: Fuel Injected 454, TH400, soon to be laying frame on 22s
96 Trans-Am: Full bolt-ons, Weld Rodlite skinnies and fatties
95 GMC Yukon 4x4: 2door all stock with the exception of glasspacks and duals
dlhughes2005 is offline   Reply With Quote
Old 11-17-2010, 02:01 AM   #7
y5mgisi
Second Chance Program
y5mgisi's Avatar
X3 for BFG
y5mgisi is offline   Reply With Quote
