Old 11-07-2010, 12:19 AM   #1
72gmcshorty
72gmcshorty's Avatar
Recommend a trans...
I have a 2006 5.3l out of a 2wd silverado. What trans would be the cheapest, easiest to bolt up to it?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 11-07-2010, 03:55 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Recommend a trans...
are you staying computer controlled with efi? if so....maybe the 4L60e or 4L65e?
If not........turbo 350, 700-R4, 200-4r, etc.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-07-2010, 04:03 PM   #3
mongoose
mongoose's Avatar
you on bcgbody?
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 11-07-2010, 10:57 PM   #4
72gmcshorty
Originally Posted by mongoose View Post
you on bcgbody?
yes, just noticed you as well....
1992 Gmc 2wd
Old 11-15-2010, 12:13 AM   #5
Critter
Future TOTM Winner
Critter's Avatar
The cheapest and easiest will be by far the regular 'ol 4l60e. It's basically the only trans that could have been behind that engine from the factory so the crankshaft flange, wiring connections and computer will already be expecting to see it back there. No reprogramming for a different computer controlled trans OR reprogramming to accommodated for an older NON-electronic th350, 700r4, sm465 etc. Just plug-n-play. Not to mention the 2wd 4l60e is the most common trans from that body style truck and are very reasonably priced.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 11-15-2010, 04:05 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
4l60e as the others said will be a direct bolt-up and probably the cheapest. However, you do sacrifice some measure of strength with that option.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-15-2010, 04:54 PM   #7
Super73
Super73's Avatar
You could also do a 4L80E with manual valve body. No wiring at that point excpet for the vehicle speed sensor and verter lock up... No after market controller, no repining the factory connector or using an adapter harnes.. Just a tough as nails option.
I picked up my manual valvebody with T-brake for under $275 shipped to my door.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-15-2010, 05:38 PM   #8
LEEVON
Moderator
LEEVON's Avatar
Lots of questions? vehicle, EFI or carb on the 5.3L...
If you're serious about your initial quest for the "cheapest and easiest" I would have to respectfully disagree that this fits the bill. 4L60e is a superior transmission but not the cheapest, you find them used for about $500-700 and new/rebuilt for about $1300.
A TH350 or TH400 would be the cheapest and easiest, you just need an adapter and bolts (about $45). Plus you get to use a cable speedo if that's an issue in the car. It's old technology and losing a gear but take the price of either of these transmissions and add the $45 and bam, you're there. You'll have to flash the computer for a manual trans but if you're using EFI you have to have it programmed anyway, no added cost.
But my vote is Super73's suggestion of a 4L80e manual valve body FTW!!!
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-15-2010, 05:56 PM   #9
Critter
Future TOTM Winner
Critter's Avatar
Super73 and Leevon, I can't argue with what y'all are saying other than I was putting more emphasis on the "easy" aspect I guess. Both of you are probably familiar at this point with what adapts to what and where to get crossover parts etc. But if someone is unfamiliar with all this I still think the original style 4l60e is worth the extra $200 (give or take) when considering everything bolts up and plugs in just where it should go. With the older trannys that were mentioned he would have to adapt the tv cable to the dbw throttle assembly, not to mention you wouldn't have overdrive with the th350 or 400. But like it has been said, everyone is entitled to their own opinions, and neither of us is wrong. More info from the original poster would probably help narrow it down though.
Also...just for reference, a salvage yard 4l60e with under 60,000 miles can be had in my part of the world all day long for $600. With that low of mileage I wouldn't be afraid to run it as is without rebuilding it.
Old 11-15-2010, 07:07 PM   #10
LEEVON
Moderator
LEEVON's Avatar
We're all just filling in the blanks for him, lots of good info here. I would be a toss up for me too if I was going with an automatic, just wasn't sure what his goal really is. I guess I had really cheap in mind, like a used craigslist TH350 or TH400 for $200. If I just had to get a truck going, everything else be damned that's what I'd do.
Old 11-15-2010, 11:23 PM   #11
72gmcshorty
I'm going with an automatic. The motor i bought came with all the wiring harness including the drive by wire pedal assembly. It's hard to find the 4l60's here for under $600. Place here sells rebuilts for $900. Not used to paying so much i guess
1992 Gmc 2wd
Old 11-15-2010, 11:57 PM   #12
72gmcshorty
so something like this is decent?
http://vancouver.en.craigslist.ca/va...052809849.html
1992 Gmc 2wd
Old 11-17-2010, 07:03 PM   #13
LEEVON
Moderator
LEEVON's Avatar
Originally Posted by 72gmcshorty View Post
It's got the right upgrade stuff for sure, that's a good price too (CN or US?). I had a 700R4 built to pretty much the same specs and it's holding up fine. I'd check them out very thoroughly. The disadvantage is that now you have to run the TV cable, and to my knowledge that can only be done with a kit from bowtieoverdrives.com made just for the drive-by-cable (99-02) intake/throttle body. Not too expensive but it will require you swap the intake. I've got one for $50 if you need it.
Old 11-17-2010, 10:53 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
4l80e with a full manual would also be no where near cheap compared to some of the other options.
Old 02-11-2011, 09:04 PM   #15
72gmcshorty
so i've not been able to find a 4l60 or 80 that will directly bolt up to this motor. I need to find something soon. I want something for daily driving/cruising. What years/model should i look into?
1992 Gmc 2wd
Old 02-13-2011, 12:27 AM   #16
clinebarger
99-06 2WD 1/2 ton Chevy/GMC truck (including 1500HD), Tahoe, Suburban, Yukon YukonXL, SSR, Trailblazer & Envoy with the 4.8, 5.3 & 6.0 will work.
98-02 Camaro Z28/SS & Trans Am 4L60Es will work also, But they dont have the neutral safty switch mounted over the shift selector shaft, Not a big deal on a conversion.
clinebarger is offline   Reply With Quote
Old 02-13-2011, 01:28 AM   #17
72gmcshorty
Those are the ones i have been looking for and cannot find locally on Craigslist. Crazy. Going to have to try wreckers. Would a trans from a 6cyl work?
1992 Gmc 2wd
Old 02-13-2011, 01:35 AM   #18
Critter
Future TOTM Winner
Critter's Avatar
Try this link, great way to browse the salvage yards from the comfort of your couch.
Old 02-13-2011, 09:21 PM   #19
clinebarger
A 4.3L 4L60E can be made to work with this http://www.gmpartsdirect.com/results...umber=12621399 But the lower bolt holes in the bellhousing will NOT line up with oil pan, And they have a 298mm converter V.S. 300mm on a Gen III 4L60E, They also dont have the very top bellhousing bolt hole. The 298mm 4L60E is a compromise in my opinion!
Heres a chart so you can identify a domestic 300mm 4L60E, The large bell V6/V8 transmissions are 298mm.
Old 02-15-2011, 10:56 PM   #20
72gmcshorty
my blazer is going to be automatic. Do i need to look strictly at 2wd vehicles?
1992 Gmc 2wd
Old 02-16-2011, 12:57 AM   #21
clinebarger
I was talking about 4L60Es the whole time??? 4WD models will have a different output shaft & will have to be converted to 2WD.
Old 02-18-2011, 09:29 PM   #22
72gmcshorty
What is involved in converting to 2wd? Found a guy with motor and tran out of 1999 suburban. He's willing to sell the trans but it's 4x4.
1992 Gmc 2wd
Old 02-18-2011, 09:42 PM   #23
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
The whole trans must be disassembled to change the output shaft,
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-18-2011, 11:06 PM   #24
clinebarger
A 99 suburban would have a 5.7L Gen I Vortec & a 298MM 4L60E, Keep looking. To answer your question on the 4WD to 2WD, You will need a 2WD extension housing, Output shaft with the VSS reluctor wheel, VSS sensor, Then the trans will need to be torn down to the Input Planetary gear set to access the output shaft snap ring.
Old 02-20-2011, 02:21 AM   #25
72gmcshorty
Since i am having no luck finding a direct bolt on wire up option, what would be the next easiest option for me? Again, it has to be auto and prefer something for daily driving. The engine is drive by wire
1992 Gmc 2wd
