11-07-2010, 01:48 AM | #1 |
My 14 Bolt Build
I wanted to put a 14 bolt in my blazer for durability and because we got a travel trailer. I didn't want to give up my wheels (6 lug) but I wanted the full floating axle. So I opened up the wheels center hole and got to work on the hubs. I used front rotors and calpiers from a '77 3/4 ton, and fab'd up some brackets. On the hub itself I drilled out the existing 8-lug pattern and tapped it for a 5/8-18 bolt to bolt the rotors to and also to plug two of the holes for the 6-lug overlap. Then came machining the bolt pattern, I used stock 12 bolt rear axle studs and counter bored the hub to accept them. Then turned the outside of the hub down to fit inside the wheel. I did end up having to turn down the heads of the socket head cap screws to get the wheel on. Every thing fit together great! Even my modified Gov-Lock has held up so far.
72 K5 4x4 350 70 Nova 454 5spd 4-link |
11-07-2010, 01:50 AM | #2 |
Re: My 14 Bolt Build
More pics
11-07-2010, 01:51 AM | #3 |
more pics
11-07-2010, 02:41 AM | #4 |
60-66 Nut
Very interesting and nice work. It must be nice to have a lathe and a mill so projects like this only cost you some time. Did you have to grind the caliper much to fit the 15" wheels.
11-07-2010, 07:26 AM | #5 |
very nice work. love the fact you went with rear discs also.
86 Suburban 2WD = rolled it and totaled it 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
11-07-2010, 09:11 AM | #6 |
Resident of Here
Nice! *high five*
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
11-07-2010, 12:29 PM | #7 |
I did not have to grind the calpier at all (thankfully) but it is real close.... enough to knock off my wheel balance weights
11-07-2010, 03:25 PM | #8 |
very nice. neat to see a 6 lug on a full floating 14.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
11-07-2010, 09:58 PM | #9 |
Excellent work for not using an indexer!!!!!!!You just gave me an idea!Thanks!!!!!!
11-12-2010, 12:01 PM | #10 |
How much time did you have invested in that? I'm guessing the stock center cap has no chance of fitting?
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
11-29-2010, 11:52 PM | #11 |
Interesting job you did, i might do the same...i have seen several posts about converting the 8 lug to 6 lug but thoose guys usually buy a kit for it, good thing i god a buddy that has a machine shop..
11-30-2010, 02:25 AM | #12 |
I guess it goes without saying that having the right tools for the jobs makes a world of difference.
72 Chevy C20 Longhorn 72 Chevy, K20 Custom Camper 67 Chevy, LWB, C20, 350/350, PS, PB, 65 Jag MKII |
12-02-2010, 05:05 AM | #13 |
Junior Member
Please tell me what you are now doing for an e-brake. Ive got a 14 ff that is going under my 72K5 some day and will need some type of ebrake.
72 K5/10/20 Hybrid 350, 465/205 44/14 bolt 35s, Detroit locker 89 XJ Pioneer, 4.5" 32s. 98 ZJ DD. Parting..87-01 Cherokees I bore throttle bodies-PM me for details! |
12-02-2010, 05:13 PM | #14 |
I am swapping a 14bolt with discs in my Blazer and will be using a High-Angle-Driveline T-case ebrake. You can also use Caddy Eldorado calipers that have a built in ebrake but I hear they are expensive and hard to adjust.
12-02-2010, 06:09 PM | #15 |
6>8 Plugless........
Very nice job Coyote72! I'm guessing you could start doing this service for other member's hubs real easily.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-02-2010, 08:25 PM | #16 |
Windy Corner of a Dirty Street
Nice job Coyote! I saw a few people rework 14FF to 6 lugs and yours is definitely the cleanest job!
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
12-05-2010, 11:20 PM | #17 |
For the E-brake I am thinking of using a hydraulic valve... kinda like a line lock but without an electronic solinoid. There is a company that makes a valve for that purpose. They are kinda pricey that I remember, I was going to try some alternative routes, maybe like grainger or something. I thought about the caddy calipers, but the cost of them new, or going through junk yards and rebuild didn't appeal too much to me. I was hoping to find a valve with a lever and use my parking brake release to set and release...
12-05-2010, 11:33 PM | #18 |
Keep us all posted. Several of us want to go the route of rear disks but need a park brake without dealing with the hassles of the Eldorcrapo rear calipers. I really wish someone would come up with a kit to retrofilt the rear disk brake set up like what is on the 2001 and later Silverado/Sierra HD trucks that has a park brake drum inside the rotors.
12-09-2010, 02:51 AM | #19 | |
i think bugpak makes them Last edited by Franks Fab Shop; 12-09-2010 at 02:52 AM. |
12-09-2010, 10:55 AM | #20 |
12-09-2010, 09:08 PM | #21 |
do you think it weakened the rim by removing the inner lip?
they also make disc e-brakes for the driveshaft... not cheap either.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 12-09-2010 at 09:09 PM. |
12-17-2010, 05:59 PM | #22 |
Thanks for the input on the parking brake. I think I will try the vw place, I've seen it before. I'm sure it will be ok as a parking brake, sometimes you just need a little extra. If I had a manual trans it would be a different story.
As for the wheels I did some research on reproduction wheels and they are made without the lip. The wheels no longer locate on the 'hub' anymore, but on the wheel studs. I figured if there are 6-lug wheels made out there with a 4.25" hole, it would be ok to machine mine.
12-17-2010, 11:19 PM | #23 |
God is good!
Speedway Motors has a similar e-brake lock.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
12-20-2010, 11:12 AM | #24 |
http://www.mico.com/products/displaysubinfo.php?id=43 This is what I have been using for years now. Mostly as a third foot when wheelin but I do use it for temp parking brake...I wouldn't want my calipers to be at pressure for long periods of time..seams too me the seals would were out quicker but that is just my opinion. I did test it overnight when I first installed the lever lock and I did not loose any pressue to the calipers. Also I never did hook up the low pressuer alarm switch it comes with, buzzer or light type.. Good Luck and awesome job on the 6lug conversion!!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks Last edited by Burt4x4; 12-20-2010 at 11:13 AM. |
12-20-2010, 02:02 PM | #25 | |
Local Redneck Authority
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
