Old 11-07-2010, 01:57 AM   #1
Chevorton
Speck Sheet Question
I have a speck sheet question:
I know in 1970 when purchasing a new C10 Truck with no upgrades to the engine you would get stock the 307 small block, but if you decided to upgrad your engine you could either get the 350 small block or 400 big block.
My question is, if you upgraded to the 350 or 400 would that be on the speck sheet in the glove box?
Please let me know your thoughts.
Thanks,
Chevorton
Chevorton is offline   Reply With Quote
Old 11-07-2010, 05:48 AM   #2
Blazer1970
Blazer1970's Avatar
Re: Speck Sheet Question
Yes, it would be on the SPID.
Blazer1970 is offline   Reply With Quote
Old 11-07-2010, 06:11 AM   #3
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Thanks,
Chevorton
If you are talking about a factory upgrade then agreed, this would be on the SPID.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 11-07-2010, 06:58 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
IIRC the original stock non upgrade would be the 250 6Cyl.Then the 292 and up as you described.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-07-2010, 07:21 AM   #5
rsavage
rsavage's Avatar
If your VIN begins with CS it began life as a 6 cylinder. If your VIN begins with a CE it began life as an 8. Base 307 doesn't show on the SPID. Don't know about what 6 cylinder engines show up as optional on the CS trucks.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 11-07-2010, 09:33 AM   #6
292 on CS models.Some don't realize but there are two of every model.In 2wd it's CS and CE and in 4wd it's KS and KE for each model within the same wheel base and body/bed type.
Old 11-07-2010, 01:32 PM   #7
Chevorton
Thanks for the reply's everyone.
My Vin number begins with a CE, so I know originally it came with a V8, it does not have the 350 upgrade on the speck sheet, so I imagine it came original with a 307, but I just wanted to make sure what I was thinking was correct.
Thanks,
Chevorton
