keep the 3 spd or upgrade to a 4 spd
hey everyone i have my '68 C-10 2wd and keep getting told to get rid of my 3spd for gas mileage and so the r's aren't so high on the highway. im not sure what to do. I plan on putting in a floor shifter and keeping it a manual. any thoughts? thx for any help!!
I am a Referee of life.
Re: keep the 3 spd or upgrade to a 4 spd
If you're looking for milage don't bother with the 4 speed.The final (high gear ratio) in both is 1:1.You'll have more even RPM thru acceleration but the same RPM at cruise.If you want floor shift and improved milage search the FAQ's and build threads for a 5-6 speed swap.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
I just switched my truck from a 3-speed to a 4-speed. It's much better to drive with the extra gear, more fun too! The final drive in a 3- speed is 1:1 ands should be the same in a 4-speed unless you got some kind of overdrive. So it'll pull the same rpms going down the hwy. My 3-speed pulled 2400 doing 60 and so does the 4-speed. You'll only gain an extra gear before the final drive,(1:1). But you'll be happier with the 4-speed,IMO.
Posted via Mobile Device |
Wouldn't bother with it. Like PanelDeland said, the top gear in both cases is 1:1. As for being more fun, again, I don't think a 4-speed is that much more enjoyable to warrant getting rid of your 3-speed.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
The only 4 speed that will help your revs and gas mileage is the A833 or MY6 used in GM trucks about 82-87. This is a Mopar car 4 speed with the gears rearranged to give you overdrive in 4th. I recommend this box if you can find one, but they are rather scarce.
Next best would be a T-5 5 speed transmission from an S-10. I put one of these in my truck and love it, but it's not strong enough to withstand dumping the clutch with sticky tires. Another possibility is a 3 speed + overdrive, which was a factory option until 69, although not many buyers ordered it. You can use one from a passenger car, so they aren't particularly hard to find. All of the above are affordable and fairly easy to install. The 3 speed + OD is basically a bolt-in. Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
Old Skool Club
![]() Join Date: Jun 2001
If rowing through the gears is your ticket....just spend the big bucks, do the conversion to a 5-speed and add a GearVendors over/under-drive. That will double your gears and keep you busy.....
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Big Red - Now its a SWB!
The thing about the 4 speed is that unless you get some non-stock one is that 1st gear is useless. 99% of the time I never use it, it is only helpful if you are crawling in slow traffic (less clutch work), or if you are really loaded and need to go up a steep hill (I didn't need to use first when I had almost 2 tons of gravel in the back or when pulling a 6000 lb trailer. So what I'm saying is my truck might as well be a 3 speed. I would say if you're going to the trouble do a swap to a NV4500 5 sp. or a T-56 6 sp., I am eventually gonna swap but haven't made up my mind as to which one. Good luck and let us know what you decide.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
