Old 11-07-2010, 08:59 AM   #1
patriyn
Remove sash channel assembly?
Any help would be appreciated on how to remove the sash channel assembly on my 69 chevy C10. The problem is that I turn the crank and nothing happens. The handle turns but the gears apparently are stripped inside? I have started to attempt this removale with not much luck. Thank you.
patriyn is offline   Reply With Quote
Old 11-07-2010, 09:15 AM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Remove sash channel assembly?
Have a read through this.....
http://www.67-72chevytrucks.com/vboa...d.php?t=157539
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 11-07-2010, 09:32 AM   #3
haysonj
haysonj's Avatar
This is not the easiest thing to do but with a little patience it can be done here are the steps as I remember them, Its been about four years since I did it.Remove the handles and inside door panel.
1 With window down remove bottom felt by gently prying up and in do both sides
2 remove wind wing window I believe there are three screws on top and one bolt at bottom of track
3 Remove other track by removing bolt at bottom and pulling the entire felt/ rubber out of track then remove track
4 The piece that holds the glass has a slot in it for the roller to come out you will have to raise the glass til the roller lines up with that slot then you can remove the glass up through the top. After that just unbolt the mechanism and remove it. You can buy a new one through a vendor on this board or LMC. Go to page 16 of the LMC catalog to see all the components. Hope this is accurate and helps you
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
