![]() Join Date: Oct 2010
Windshield wiper motor bracket problem
I have a problem with my windshield wiper motor bracket.
The cab is VERY clean except for some reason, the windshield wiper motor bracket is rusted along with the area around it. This link and this link shows the area I'm talking about (note, this is not pics of the one on my truck). Does anyone know where I can get this area? That bracket is welded on, so I would need this complete area around it. Is the only way I can get this area possibly from a parts truck? Thanks!
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
Re: Windshield wiper motor bracket problem
I don't think I've ever seen it in a catalog, although I can't say I've ever gone looking for it either. I would think that it would not be that hard to grab one from a parts truck. Looks to be about 6-7 spot welds there?
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yep you're going to have to get that piece from a parts truck.
Yea, it's a bummer. Not only do I need that bracket, I need a portion of the cowl 'tunnel' that holds that bracket (probably would end up being a 8" x 8" or so section with that bracket attached)
This is a VERY clean rust free cab to. I'm guessing one of the windshield washer hoses had a leak it in, and it sprayed inside the cab on the bracket area and eventually rusted out.
60-66 Nut
It shouldn't too hard to find a good donor cab. I can't say as I've seen one rusted out in this area.
| Bookmarks |
