Old 11-07-2010, 09:09 PM   #1
emil77
Fuel tank capacity and shut off question.
Hi guys,
On my '72 C20, what is the fuel tank capacity? Also, am I correct in that unlike modern cars the gas pumper won't shutoff when capacity has been reached? I have to hold it and keep an eye on the gallons I've pumped, right?
Thanks,
Emil
1972 Chevy C20
emil77 is offline   Reply With Quote
Old 11-07-2010, 09:54 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Fuel tank capacity and shut off question.
20 to 22 gallons.
What you've been told is bogus. The tank doesn't tell the pump when to shut off, the pump tells the pump when to shut off
Old 11-07-2010, 11:00 PM   #3
AirSpeed
AirSpeed's Avatar
I have to put the handle in the tank as far as it will go and fill it up on the first notch on the lever, if I fill it up fast it turns off about every 10 seconds. Once my tank is full the pump shuts off automatically, it fills the tank up to about 3 inches off overflowing.
AirSpeed is offline   Reply With Quote
Old 11-07-2010, 11:52 PM   #4
emil77
Great, thanks for the info!
Thanks,
Emil
1972 Chevy C20
Old 11-08-2010, 08:35 AM   #5
21 gallons.A properly working gas pump will cut off.
