Grandpa in the rustmobile...
Leaking water from front of motor...
Ok, I went outside saturday morning and was leaking water from the front of my motor in my truck (350).
It had about 50% of the antifreeze it should have and it got down to 28-29* weatherman said... Big puddle of green water under the truck after I let it drain. The waterpump looked cracked so i pulled it off, well no crack, so i made some gaskets from gasket material tonite and put it back together made sure everything was tight..and filled it back up, IT STILL LEAKS So i opened the draincock and came back inside Any ideas...Truck is about to go on craigslist lol its quite unreliable, I cant lie ![]()
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
yes, i do
Re: Leaking water from front of motor...
Did you check your hoses? Also did you look for drips or drops from where ot could be leaking? Did you check/replace the gasket thats on the back of the water pump? Its the impeller plate gasket. If you look at the back of the water pump and see the plate that has 6 bolts on it there is a gasket that goes there
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
#3 | |
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
The pump was replaced with my new motor (Pump came from....autozone or somewhere)
So it probably has less than 1000 miles (no speedo) I bought it in late august..but havent been using the truck since late september
Hoses are all tight and dry...
The gasket with all the lil bolts sounds good to me...But its brand new?
![]() Join Date: Jul 2009
Are your heater hoses tight? I also have had "new" rebuilt pumps fail.
Fun Stuff
![]() Join Date: Jan 2010
there is a weep hole behind the pully under the front of the pump where it will leak if the seals on the shaft have failed.
Note: The pump in the pic is a newer version. It is basically the same, only decent pic I could get right now.
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd Last edited by jayman68; 11-07-2010 at 10:13 PM. |
dazed and confused
hang in there man!!
members met: redbaron69, billsbowtie,nc67 |
![]() Join Date: Sep 2000
There is a hole in the water pump near the pully on the bottem side if it is comming out there you need a new water pump. The seal is out.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
Wow! Thanks you guys ROCK!!!!
Ok, just for kicks, what would cause the seal to go out? Could I take the pulley off and put water in it to verify its comming out of that hole? Jayman, thanks for the pic, I preciate ya crawlin under your truck for apic! That says alot lol bigguy, thanks, I need it
![]() Join Date: May 2009
Yep. Also, did you use thread sealant on the water pump bolts, couple of them go through waterjacket. Just a thought.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
I had the same problem thought the back plate seal was bad so i pulled the pump off(in my apartment driveway and spilled antifreeze all over
#13 |
Never trust the parts guy, most of the time they are a bunch of idiots behind a computer screen.
1970 GMC truck ![]() 1988 Harley 1200 Sportster ![]() |
#14 | |
Being one of those "Parts Guys", (for 10 years, back in the 70's), I prided myself on being Knowledgable and getting that part right the FIRST TIME. Had no computers back then either. Actually had to look the part up in a big "Bank" of Parts Books. Then on top of that Laborus Task, I had to actually accept funds and COUNT BACK CHANGE, without having a Cash Register TELL ME how to do that! Ah the good ol' days..... ![]()
#15 |
yes, i do
i find with most parts houses that i visit i have to pick and choose who i talk to and always, always look at the part before i buy it. i haven't had any problems since i have been doing this
#16 | |
Junior Member
After working in retail for 8 years I just gave it up and decided to just take breaks and be happy, put the wife to work, lol. Unfortunately no matter how knowledgeable the parts guy is other factors can cause having the wrong part in a box. Packaged wrong at the manufacturer or the wrong one returned in a box by a repair shop are a couple. The large box stores are not able to hire experienced help with the very low pay they offer so it is real important for the customer to be a part of the process to get the right parts, unfortunately. When I am looking for parts for my old trucks I spend a little extra time researching on the computer at the big box store web-sites which helps some. Also I try to take the old parts with me to compare to the new parts to make sure things look right. I do share your frustration with the "Idiots behind the computer screen" though, lol. I guess since I was one of "those guys" I try to be a little more patient when I go looking for parts. Sorry I got off subject a little.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
#17 |
![]() Join Date: Jan 2009
I don't trust autozone water pumps on my $4000 motor.............I would buy at least NAPA.....new....not reman is best
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
#18 |
Old Skool Club
![]() Join Date: Jun 2001
I replaced the water pump on my '65, back "in the day" and found it to be leaking when I was refilling the radiator. It looked like it was coming from the back of the pump....and it was. So, off with it all and back to the parts store. It was a reman and opted to go to NAPA and get a new 'un.
The cover on the back of the pump is held on with bolts and may not be tightened, properly. I know now that I have to check those if I ever have to replace another pump, but a little fore-hand knowledge could save you a lotta work. Yeah, it's the responsibility of the reman guy to do that, but whose work is going to matter more at the time you're ready to fire it up? Yes, I have pulled wrenches and I have worked the parts counter. Did I think to check that cover? Nope....never had one to leak before. But, now I'm wiser.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#19 |
So try tightening the bolts on the back and putting sealer on the 4 mounting bolts? Or Check for water comming out of the weep h ole?
#20 |
Its not the hoses...
It was wierd because it didnt do it until the cold night we had (upper 20\'s)
#21 | |
Junior Member
In this part of the country Napa and Fishers have good quality parts, followed by O'Rielly's and Auto Zone is dead last as far as I am concerned.
#22 |
I beg to differ cause my brand new quality NAPA water pump was made in china.... Go figure... sigh
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#23 |
Ok, Truck fixed herself I guess.
I came home today (Nice weater, almost dark, UGH stupid time change lol) And put water in it warmed up etc etc NO LEAKS, drove around, no leaks, I plan on driving it morrow, But we will see. I think im going to go double check it, Im running just water tonite because its not supposed to get cold and Im change hoses out morrow just in case. Thanks for prayin' for my 68! ![]()
