Problem with drop spindles!
Hi. I am lowering my 65 C10 and I ran into a problem. I have CPPs front suspension and disc upgrade kit for my truck. I ran into a problem after I installed the spring and dropped the jack from the lower control arm. I then realized that the spindle was hitting the upper control arm and I couldn't move it. I also noticed that when I had tightened the castle nut on the upper ball joint, it had gone past the hole for the cotter pin. I called CPP and emailed them pictures. They determined that I had the right balljoint and that I just needed a washer under the castle nut to lower it so the cotter pin would work, and that I shouldn't worry about the control arm hitting because that would only happen if the truck was in the air. I am not worried about putting the washer in because I have heard of people having to do this. I am worried about being in a situation were my front suspension is unloaded and I have no steering. I am probably going to end up trimming the upper control arm, but before I did I wanted to see if anyone else had this problem. By the way, the spindles are Western. Thank you for your help.
Re: Problem with drop spindles!
I'll bet you need a washer to space the upper ball joint properly. It sometimes happens. No big deal realy, but it will drive some guys nuts because the don't think it's "right." You shim and adjust every other part of the truck, suspension included. Upper ball joint shimming is just unusual for factory stuff, but happens with aftermarket stuff.
IIRC, Scotti had a similar problem.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Happy to be here
![]() Join Date: Mar 2000
Similar problem going on in this post- LINK Please call Jeff at CPP and ask him to resolve your concerns. 1-888-522-8303 x118
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-08-2010 at 12:07 PM. |
#4 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
But it's not ok to to shim between the ball joint and the spindle. The taper of the ball joint will never seat, in the spindle. I would trim the a-arm or remove a little extra material off the spindle first.
![]() Join Date: Sep 2006
I had to trim just a little material off of my drop spindle to keep it from rubbing on the arm. It wasn't keeping it from turning, but it was rubbing. Few seconds with the grinder and it was done. Don't know what brand the spindles are but I got them from Brothers.
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
#6 | |
#7 | |
You replied, "I'll bet you need a washer to space the upper ball joint properly". I only assumed you were speaking to the original problem. Sorry for the confusion,...
