Old 11-08-2010, 01:31 AM   #1
Deep C 915
Deep C 915's Avatar
Brake conversion on 1970 4x4 Blazer
Just found the site and looks to have a good bunch of people and a lot of good info. I'm sure this question has been asked and being a newbie I don't know where it might be or if I’m posting this question in the right spot.
Hear it is anyway..
I'm starting a restore on a 1970 4x4 blazer and looking to get different ideas on converting over to Disc brakes.
Would like any input ranging from cheapest, easiest, maybe one if I had a little extra money that month.
Deep C 915 is offline   Reply With Quote
Old 11-08-2010, 09:04 AM   #2
Savage69K5
Re: Brake conversion on 1970 4x4 Blazer
I'd look at find a disc brake D44 and swap out the whole thing. I went through this similar issue on my 69 earlier this year. I ended up snagging a free disc brake D44 from a guy in Round Rock, and just swapped out front axles. You will need a new proportioning block as well.
I'm in Houston as well (Magnolia). Not many older K5s rolling around this town.
Savage69K5 is offline   Reply With Quote
Old 11-08-2010, 06:50 PM   #3
Deep C 915
Deep C 915's Avatar
Thanks for the responce & that's the 2nd. time I've gotten that advice. I will start the dismantle next week. I'm not going to rush it being that this is my first attempt at restore so I will be doing alot of labeling and identifing parts for reassembly.Was that the only thing you had to change out in the break system. ?
Old 11-08-2010, 08:26 PM   #4
Savage69K5
The axle I got was out of a 77, and it had full time all wheel drive, so I had to install some Warn hubs in it to make it part time. Depending on what axle you get, I think the banjo fittings that go to the caliper may be different. My solution was to get Inline Tube fab me some stainless braided lines with the 69 frame fittings and the 77 caliper fittings. Works like a champ. Everything else bolted back up.
I believe the later D44s (post 72) have a stronger u joint as well.
Old 11-09-2010, 03:49 PM   #5
71blazerdetroit
Definately get a post 72 dana 44, (bigger bearings, u-joint and i think axle shafts are bigger)
Since your changing over to disc and need the new proportioning valve, I assume your doing the rear also? if you are, now is the time to re-gear if necessary. You might find a set of axles with better gears for you app.
Depends on your finished tire size and trans.
71blazerdetroit is offline   Reply With Quote
Old 11-10-2010, 11:25 PM   #6
Deep C 915
Deep C 915's Avatar
Just saw some complete axle assemblies on 4wheel parts, I think I will be shopping around and try to rebuild a set of Dana 44's as suggested. I won't be doing alot of aggressive off roading (mostly sand) My tire size wil be 33-35" and have no plans to change the transmission which I believe is a SM465
First Gear - 6.55:1
Second Gear - 3.58:1
Third Gear - 1.70:1
Fourth Gear - 1.10:1
Reverse - 6.09:1
How do I decide what gears I need?
