Old 11-08-2010, 03:29 AM   #1
DBear
DBear's Avatar
probably a dumb question
I was curious as to what is required to run 8 lug wheels on a 71 1/2ton 4x4 burb? would i have to swap out differentials or what? Just looking for the cheapest route. In advance, I know this is probably a dumb question.
DBear is offline   Reply With Quote
Old 11-08-2010, 04:12 AM   #2
wHATANERD
wHATANERD's Avatar
Re: probably a dumb question
This might work:
http://www.ezaccessory.com/ProductDe...-8650&click=35
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 11-08-2010, 07:33 AM   #3
There's adapters,or you can find complete axles for reasonable money and just swap them.
Old 11-08-2010, 12:20 PM   #4
68chevyfuelie
68chevyfuelie's Avatar
Depends on the axles you're running. Assuming it's disc brake up front, and a Dana 44, just change your wheel bearing hubs. Just match your hub size to the spindle size. Easy, should take you a couple hours. If you have a 12 bolt out back, you'll have to use adapters or swap to a Dana 60/14 bolt/Eaton/something else.
68chevyfuelie is offline   Reply With Quote
