72 C20 rear end
Hello there been a lurked here for a while, but here goes my first post. I have a 72 c20 with a Dana 60 rear, he drivers side inter bearing locked up and spun the race out of the floating hub. After after calling around to parts store and the GM parts counter. I am stuck at a place where I can't get a hub and the old Dana is in good shape.
So I guess I need some help finding the part. Or to start looking for a new 8 lug rear end. Any input would be nice. Thanks in advance ,Adam Edit* axle tube build number 603322 Last edited by Plottski; 11-08-2010 at 09:31 PM. |
its all about the +6 inches
Re: 72 C20 rear end
leaf or coil rear suspenton?
What do you use the truck for? Do you have welding/fab skills? |
Re: 72 C20 rear end
It's a leaf Dana.
Driver, pull trailers, haul wood and light farm use. I have welders and torches. I could do perchs and shock mounts. Cutting tubes no couldn't do that. So I guess if I had interchangeable wheelbase I could get it to work. I would love to get parts for the rear end that's in I however as it has new bearings and brakes. Posted via Mobile Device |
Re: 72 C20 rear end
Post a link from your first post into the 4X4 section and ask them to come here and read this post, forum policy is not to double post, I say this because there are more gear heads in there that may be able to offer advice on a source to buy parts on line.
Go to the "#1" on the right top of your post and right click and choose "copy shortcut" then paste into the new post over there. http://67-72chevytrucks.com/vboard/s...58&postcount=1
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Re: 72 C20 rear end
I'd look for a later model 14 bolt. It's a beter, stronger rear, and with just some spring perches and shock mounts welded up, it'll bolt in
Re: 72 C20 rear end
Yea pity I got a few hundred in new bearings and brakes in this rear. I was rebuilding the whole thing when I got to the driverside and the inner race fell in place.
Are all trucks the same wheelbase? Posted via Mobile Device
72 C20 350/TH400 67 Chevelle 454/th400 |
Re: 72 C20 rear end
no, all trucks are not the same wheel base... not sure what it matters.
Re: 72 C20 rear end
Not sure why I said wheel base I shoulda said axle width in chevy trucks.
Junior Member
Re: 72 C20 rear end
I picked up a 72 leaf Dana 60 from a board member for a hundred bucks. Pay to be a subscribing member and post a WTB. A rear end swap is probably cheaper than parts plus you can swap your new parts to the replacement rear end.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
Re: 72 C20 rear end
Yea this is what seems to be the way its gonna be.
Re: 72 C20 rear end
I found a dealer that had an nos hub.
