Old 03-20-2002, 08:46 AM   #1
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Post Heater core, A/C or non-A/C??
Whats the difference?? When I ordered the heater core for my Burb he asked me if it was factory a/c, but the one in my Burb "looks" the same as the one in the non-a/c step. Is there gonna be something different about changing the a/c one?? Just curious what I may run in to, I dont know if I dont ask. Thanks guys.
SILLY BOYZ......TRUCK ARE FOR GURLZ !!
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 03-20-2002, 09:33 AM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Post
Now it has been some time since I did the swap on mine, but I do recall that the non ac core is much different. I believe the major difference is the houses or spouts that come off the core itself are shaped very differently. I believe the bottom hose on the ac version is much longer. Someone else can probably give you the specifics, but I do know they are different.
2001 GMC 2500HD Crew Cab Duramax, Allison, 4WD, Love it
1971 Chevrolet 1/2 ton 2WD Short/Step Side. In process of frame off restoration
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 03-20-2002, 10:54 AM   #3
JimKshortstep4x4
Post
The inlet/outlets on the AC heaters are almost a foot long and they curve up to the corner of the heater box because the heater core mounts at an angle. The AC tubes are so long that there is a support on the side of the heater box to hold them in place.
The non AC heater core has the tubes coming straight out at the top and bottom and they are only about 3" long. If you looked at them side by side the differences will be very obvious.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-20-2002, 01:04 PM   #4
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Post
Thank you!!!! I appreciate your help!!!!
