what do i need for disk brakes.
Hi all i am want to put disk brakes on the front of my SWB 70 c10. I work at my local oreillys auto parts and can get alot of parts from work. Does anyone know what parts i can get from my store and what parts i can get from my local junkyard. from what year truck. I can get from my work master cylinder, brake booster,calapers,rotors,hard lines and hoses. What else do i need.
I get 30% off all parts at my work so i think i can get parts cheeper then a kit.
"Your trucks fast! You must have been going 120 when I passed you." "Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay" If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties... |
Grandpa in the rustmobile...
Re: what do i need for disk brakes.
Buy ALL MOOG PARTS
Id would rebuild the whole frontend if you can.. Would you like to lower the truck? You can: -Swap a 73-87 crossmember -Conversion spindles from ECE or somewhere (fits onstock balljoints) -Order BJ's for 71 -72 get stock 71 72 bj's and press em in your new arms, rebuilt control arms and swaybar bushings, inner/outer tie rod ends etc Make sense, at all maybe? How much ya wanna spend? How low ya wanna go?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
