11-09-2010, 01:44 AM | #1 |
cab mounts??
iv never removed my cab and i know the bed sits right on the frame without bushings, with this being said i cant get the lower body line to sit right with the line on the bed, it is about 3/4 to low, would a new set of cab mounts fix this??
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
11-09-2010, 05:43 AM | #2 |
Redefining LowBudget
Re: cab mounts??
looks like a good place to start
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
11-09-2010, 07:55 PM | #3 |
Project Junkie! Fishing Poor!!
Re: cab mounts??
New cab mounts should fix it. You should also replace your radiator core support mounts if you haven't already. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
11-09-2010, 09:43 PM | #4 |
Spanked once
Re: cab mounts??
I read through your build thread and got lost on how , what you did for your track bar or watts link. The reason I ask is I took my 71 all the down and as I am putting it together I can see the bed frame is already high on the drivers side again after putting in the trac bar. Maybe a super bar would be better but I'm leaning to a watts link set up. Btw cool truck.
The ole 350 budget build. |
11-10-2010, 02:15 PM | #5 |
Re: cab mounts??
cool. ill go pick up a set of cab mounts,
wes. core support mounts are done!! richard h. not too shure what you mean but the bed frame being higher but when i did the air ride i installed and adj rear bar. rite now mine sits higher on the pass side due to the exhaust tube hitting the axle, i still need to fix that. also there is some sort of problem in the pass front, it wants to sit higher eversince i took out the coils the po had in there, ive replaced all controll arms/shafts and new spindals. i think it was in a fender bender at one time and i might need to have the frame tweeked.
