11-09-2010, 11:32 AM | #1 |
It followed me home?
88 tbi need smog help please
Just ran the dually though smog and failed, any suggestions?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
11-09-2010, 12:12 PM | #2 |
Slots go on anything!
Re: 88 tbi need smog help please
What test do they do in CO? They did a two speed idle test here, but did not put my dually on the rollers. mine passed with flying colors, but I did add some denatured alcohol to the tank before the test, just in case.
1974 Jimmy- 5.3/4L80e/NP241 |
11-09-2010, 12:23 PM | #3 |
From the test data, based on CO2% values I would say that your engine is running very rich at idle. From ideal Stoichiometric charts CO2=11.8% is equivalent to 13.25:1 AFR (which is very rich!) From Stoich charts running at 13.25:1 AFR -> CO=3.5%, HC=150 ppm; CO2=11.8%.
Since your engine is TBI injected it should be idling in close loop with O2 sensor keeping AFR close to 14.7:1. It is possible that you have a contaminated O2 sensor (it will read lean mixture most of the time casing ECM to add fuel). Another possibility is exhaust leak upstream from O2 sensor - exhaust manifold to head gasket leak or between exhaust manifold and pipe (leaky donuts). Another common problem is a weak spark or misfiring cylinder or two. Misfire results in unburnt fuel and free O2 being dumped into exhaust. O2 sensor will detect extra oxygen and ECM will add fuel which engine does not need. This results in increased HC ppm and high CO% Another common problem that common to high millage TBI engines is a bad or flaky CTS - this sensor cost under $15, but ECM relies on it to set correct baseline mixture. Based on test data it does not appear the case since 2500 RPM data is closer to stoch ratio 14.7:1. Sorry for the long answer. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
11-09-2010, 12:43 PM | #4 |
Mine crushed the idle C02 number as well and passed at RPM. Weird deal, it passed both when I had the vacuum line from the EGR controller to the EGR valve plugged...
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? Last edited by Hulk Will Smash; 11-09-2010 at 12:45 PM. |
11-09-2010, 12:57 PM | #5 | ||
