Old 11-09-2010, 01:50 PM   #1
stich626
best way
to cut coils..
now I know the gaswrench is a no no.. to heat and sag..
but will cut'n with it cause to much heat?
is a cut off wheel or a sawsall better..
will be doing this to the back first as if I mess up the drop coils and raw stock to make drop blocks are cheap..
fronts I want spindles.. but like most.. money is an issue..
thanks
stich626 is offline   Reply With Quote
Old 11-09-2010, 02:22 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: best way
I used a cut off wheel. Sawsall will take a lot more work because of the spring temper. After cutting, just let it cool naturally, no dipping in water.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-09-2010, 02:46 PM   #3
jimmydean
jimmydean's Avatar
Re: best way
You can't cut the rear coils because they are tapered (unless you know something I have missed), but use a cutoff wheel and remove no more than one coil on the front.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-09-2010, 03:56 PM   #4
SCOTI
SCOTI's Avatar
Re: best way
They 'can' be cut but you have to figure out another method to secure them on the end thats cut. It's not something I would recommend doing though.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-09-2010, 04:52 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: best way
New springs are not all that expensive. Check with Summit.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-09-2010, 05:40 PM   #6
jimmydean
jimmydean's Avatar
Re: best way
Good point. More like "the approved method for lowering the rear is to purchase new springs, or bag it if blocks alone are not enough".
Cutting the front is easy enough to do, but the reality is you are working springs that are pretty old and could use a replacement anyway. But if you are looking for a "right now" option, then it's cheap and easy to do.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 11-09-2010, 10:33 PM   #7
skip99
skip99's Avatar
Re: best way
I just did this to a camaro, the thing is... if it is an old car you don't really know how far the springs have settled, I've seen guys buy "lowering springs" and actually end up higher..I bought 2" lower rear springs from global west and didnt move much..
so rather than guess on the fronts.. I cut a coil, and DON"T cut more than 1 coil. that alone will get you 2-21/2 inches.. plus spring rates blah, blah...it may not look like it it lower when you are done, but let it settle, move back and forth and it will come down, be sure and index the top of the spring , if there is a stop for it, in the a arm, the lower is just for drain..
skip99 is offline   Reply With Quote
Old 11-09-2010, 11:15 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: best way
I agree that its better to buy new rear coils, or find used Jeep coils for the rear. To answer your question about cutting in general, there are several way.
A cut off wheel in a high speed grinder is the easiest and obvious first choice. If one is not available you can also use a thin "tile' blade in a circular saw. It pretty much the same thing just bigger.
If your only tool available is a torch, it will work in a pinch. If you submerge the spring in a 5 gallon bucket of water leaving the coil that need to be cut exposed, you can cut the spring with a fine tip without using excessive heat. Allow the spring to cool naturally and the tempering will be just fine.
Speaking of tempering, the spring is tempered but not hardened. Believe it or not you can cut one with a sawzall, or even a hacksaw. The trick is to keep the spring stationary while cutting it.
Proving once again there are many ways to skin a cat...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-06-2011, 06:29 PM   #9
brans72
Re: best way
can anyone show a picture of one coil cut off just spring part? Thanks
brans72 is offline   Reply With Quote
Old 02-06-2011, 07:16 PM   #10
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: best way
Cut coils/jeep springs check build for pics
John
1999 Toyota Tacoma 4x4
Old 02-06-2011, 09:34 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: best way
oldblue1968chevy,... are you really happy enough with your "rear Jeep spring" swap to continue to recommend them?
I thought you posted one time,... that they were fine, as long as you didn't carry over 100 lbs. in your truck?
If that's the case,... I wouldn't recommend them to anyone.
Keith
Convert to disc brakes.
Old 02-06-2011, 09:53 PM   #12
Shane
Shane's Avatar
Re: best way
late '60's / early '70's malibu/chevelle rear coils work too ...
Shane is offline   Reply With Quote
