11-09-2010, 07:42 PM | #1 |
well guys here it is 71 long bed
Well here it is 1971 chevy c/10 it has a 350 and a three on the tree and you guessed it lots of rust but thats a battle for a diffrent day this is my first chevy truck to restore so its going to be a learn as I go process.
The first goal motor swap!!!!! I will be posting pictures of it once I get it done. The first problem I have run in to cant get the motor out its stuck on something. I have everything disconnected and I can lift the motor up a little bit and rock it back and forth but its still not letting go. There is even a gap in between the bellhousing and the block Last edited by mrsmothers; 11-09-2010 at 07:47 PM. |
11-28-2010, 08:27 PM | #2 |
Re: well guys here it is 71 long bed
Well small up date and pictures should follow tomorrow. Its at the shop right now getting a few small things done. Normally I dont use shops but I was way to tired to finish up wireing due to the fact that in three days I compleatley restored the engine bay and did a motor swap , u joints, clutch ,rad, trans fluid, rear main seal , new gaskets and minor work on the 12 bolt, all new hoses all the way around the truck , got the three speed working agin.
Now the fun part when it gets back..... all new sheet metal yay... all said in done I am hopeing to have a full resto done in less then 4 months already off to a good start. |
11-28-2010, 10:39 PM | #3 |
Grandpa in the rustmobile...
driveshaft still connected? speedo cable? trans mount (really bellhousing mount if 3spd)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
11-29-2010, 01:11 AM | #4 |
It was a lip on the bell housing I had to pull them out together. It almost drove me crazy but its out now and the old paper weight of a motor is now in the scrap pile.
