Old 11-10-2010, 02:18 AM   #1
momo805
dynamat options??
i cant find it now, but i saw a thread that talked about other sound and heat deadening materials, even some at home depot that were just as good but a lot cheaper. does anyone know of any?
momo805 is offline   Reply With Quote
Old 11-10-2010, 02:40 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: dynamat options??
Perhaps post #3 on the attached thread is what you're looking for:
http://67-72chevytrucks.com/vboard/s...ght=HOME+DEPOT
Old 11-10-2010, 10:27 AM   #3
dracko
dracko's Avatar
Fat Mat
dracko is offline   Reply With Quote
Old 11-10-2010, 10:28 AM   #4
badriand
badriand's Avatar
Same thing i used. The smell is bad for a while but once it airs out it is ok.
badriand is offline   Reply With Quote
Old 11-11-2010, 10:54 AM   #5
hardwaa
hardwaa's Avatar
I also used FATMAT 80 mil from ebay . I used alluminum tape from HomeDepot on all edges and seams I did notice any odor.
I LOVE BURNOUTS:metal
NO BOZO's
hardwaa is offline   Reply With Quote
Old 11-11-2010, 11:01 AM   #6
sandnuriz
sandnuriz's Avatar
Originally Posted by dracko View Post
Fat Mat
Yeah Fat Mat for hard wood floors and like badriand said let it air out, A friend of mine that installs stereos used it when people had a low budget built works great or try Solid Sound same thing
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
Old 11-11-2010, 08:38 PM   #7
protrash64
Resistance is Futile
protrash64's Avatar
others have mentioned 'Peel and Seal'.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-11-2010, 11:00 PM   #8
1/2Dozen
1/2Dozen's Avatar
I bought a gallon of Edead v3 a month ago and applied it with a paint brush. It was enough to cover my firewall and floors with 3 coats. Here is the site where I bought it from.
http://www.edesignaudio.com/index.php?cPath=1_24
66 suburban
51 Merc 2 door coupe
38 Chevy Business Coupe (gf's)
76 Airstream Sovereign
1/2Dozen is offline   Reply With Quote
Old 11-12-2010, 02:15 PM   #9
65Gregg
65Gregg's Avatar
How well did it work?
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 11-12-2010, 04:30 PM   #10
1/2Dozen
1/2Dozen's Avatar
I was really impressed with the amount of outside noise it reduced. I did the firewall, floor and back wall behind the gas tank. I was going to apply it inside the doors but realized it would be too messy so I will be ordering their roll on type for inside the door panels.
I used a paint brush to apply. Make sure each coat is completely dried before applying another. The guy said I could use a gun to apply it and just thin it down with water. I can't remember what the ratio was but if you call them they are very helpful.
66 suburban
