Lower and Upper Control Arms
Does any one know a company that makes a stock 71-72 control arms that has bushings in the control arms rather than the stock type control arms? Or can I use other control arms from later model and keep the stock cross member for my 71? I dont want these lowered control arms that you can find everywheres. I like my stock height, just want a better ride.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Lower and Upper Control Arms
I am sure someone will chime in with more better info, but you can use upper and lower CA's from 73-87 1/2 ton, they have the shafts you are looking for, you will need new ball joints obviously and outer tie rod ends and that should do it.
LMC has them, a GM dealer might also. Are you going to lower the front any?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I dont plan on lowering it. can I use the 71-72 ball joints and spindle if I go to use the 73-87 control arms?
#4 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
The 73-87 lower balljoint is the same as your 71-72 balljoint. You will need to change out the upper balljoint because the 73-87 style is different from your 71-72 style.
but I can still use the same spindle?
Yes you can use the 71-72 spindle with the 73-87 control arms.
(upper balljoint change is necessary)
thanks lolife99 u have been a big help.
