Old 11-10-2010, 11:58 AM   #1
Plunkett
electronic carbs
So my 86 chevy silverado has a 305 with a 4barrel quadrajet carb. I didn't know it till the other day but it's an electric carb. What exactly is the difference between that and a normal carb? It looks like one of the wires from the carb goes to a spot that is screwed into the intake manifold. Thanks in advance.
Plunkett is offline   Reply With Quote
Old 11-10-2010, 12:34 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: electronic carbs
The E4ME Qjet has an electronic mixture control solenoid mounted in the float bowl to control the air-fuel mixture set by the ECM, this would be the blue plug in the pic, the brown plug on the carb at the 5 o'clock position is the TPS (Throttle position Sensor) also monitored by the ECM.
Uploaded with ImageShack.us
Malo83 is offline   Reply With Quote
Old 11-10-2010, 01:19 PM   #3
Plunkett
So can you physically adjust the air/fuel on the truck with it being an electronic carb?
Old 11-10-2010, 01:41 PM   #4
Plunkett
I just went out to my truck and I don't have the throttle position sensor on my carb. I have the blue connection on the inside of the carb tho.
Old 11-10-2010, 02:49 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Unless it is a CA emissions truck, it is not an electronic carb. The '86 has an electrical connection, but it isn't controlled by a computer. I believe it is a solenoid, controlled by engine temperature, that is used for the accelerator pump.
I might have some of those details wrong, but it should be pretty close.
Yours should have a small harness that goes to a sensor on the thermostat housing and somewhere else.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-10-2010, 03:02 PM   #6
Plunkett
Slonaker, that's exactly how my carb is. It has a spot on the thermostat housing, which that sensor is broken on the thermostat.
Old 11-10-2010, 05:53 PM   #7
Slonaker
Slonaker's Avatar
Mine was broken, too, when I got it. I bought the sensor from the Chevy dealer 6 or 7 years ago after spending a whole afternoon trying to track it down at all of the local parts stores with no luck. I didn't notice any improvement in driveability. When I replaced my engine, I bought an older style quadrajet from JET Performance, and never looked back.
If it runs okay as it is, I would just leave it. If it doesn't, I would consider replacing it with an older style quadrajet or an Edelbrock carb.
Slonaker
Stock '01 Silverado
